help needed.. will this fit?
Old Jun 11, 2007 | 02:25 PM
jcyalegre's Avatar
i have an advan super racing version 2, it is 9.5 wide with a 42 offset, i'm planning to wrap it with 245/40 r18 tires, will this fit on my evo 7? will it have rubbing issues? do i need to put a spacer? and would the tires be just right? i tried the mags on the car while the front part was jacked up, the rims cleared the brakes well but it only cleared the suspension by around 3/4ths of an inch.. please advice.. thanks in advance
Old Jun 12, 2007 | 08:06 AM
jcyalegre's Avatar
anyone?
Old Jun 12, 2007 | 08:44 AM
value's Avatar
+42 offset probably won't fit
Old Jun 12, 2007 | 12:32 PM
madmax199's Avatar
You most like will need spacers up front, some negative camber and fender rolling/pulling in the back.
Old Jun 13, 2007 | 04:57 AM
jcyalegre's Avatar
whats the thickness of the spacers that i need to use? =)
Old Jun 14, 2007 | 04:24 PM
jbrown's Avatar
Originally Posted by jcyalegre
whats the thickness of the spacers do i need to use? =)
Probably 20-25mm up front and 15-20mm in back. Fenders will definitely need to be rolled.
If you buy a pair of 15mm spacers, a pair of 20mm spacers and a pair of 25mm spacers you should be covered, then just sell / return the unused pair.
Old Jun 15, 2007 | 12:37 PM
evohumper's Avatar
Nope, there's not enough clearance for the calipers...sorry mang..
Old Jun 16, 2007 | 02:02 AM
jcyalegre's Avatar
what should be the clearance of the lip of the rim to the suspension? ummm.. it did clear the calipers, we installed it without tires a few days ago.. is it okay if i go with 245 tires or should i get 255's? advantages and disadvantages? thanks for the replies guys
Old Jun 16, 2007 | 08:29 AM
jbrown's Avatar
There's not many choices in 255/35, I think the Michelin Pilot Sport PS2 is the best and it's pricey, most of the rest in that size are crap.
Old Jun 18, 2007 | 06:41 AM
jcyalegre's Avatar
ic.. so i should just get the 245's? would it be too stretched out?
