rubbing on 255/35/18
Old Jul 15, 2007 | 05:36 PM
kryptonitex's Avatar
And I am on swift sport springs...
If you need it quick just order the fender roller new.
Only took 2-3days for mine to come in.
Old Jul 15, 2007 | 05:37 PM
And I am on swift sport springs for the MR.
If you want it done quickest and safest, just order the fender roller from eastwood.
They got mine to me in 2-3days.
Old Jul 16, 2007 | 01:17 PM
Corey's Avatar
I had 18X9 RG2's on my old EVO with 255/35's as well. When I first put thme on I was on Tien S-Techs and really didn't have a issue with rubbing. It was due to the negative camber I was running with those springs. Once I put some coilovers on the car and the camber changed, the rubbing started. It all comes down to tire size and offset.
Old Jul 18, 2007 | 08:34 AM
MirzaJinnah's Avatar
I am having similar problem except I experience a small bumb rub tot the strut (behind wheel/tire) when I carner to hard or hit hard bumb to fast..
Just recently mounted 245/35/18
can this be corrected by spacing the wheel a small amount? or even better by going to aftermarket suspension???
Old Jul 18, 2007 | 09:27 AM
SPANKED's Avatar
I'm running 255/35/18 Falken FK452s on 18x9" +30 offset dropped on Tanabe springs with no rubbing. I'd get the car lowered and aligned before rolling your fenders. If you get a good alignment they may be able to work out the rubbing issue by playing with the camber.
Brokeassevo
Aug 4, 2017 08:15 PM
whiterabbit
Apr 12, 2016 08:12 AM
triso
14
Apr 13, 2010 09:48 AM
EndlessRed
30
Nov 8, 2009 12:43 PM
xxevoxx
Apr 9, 2007 06:50 AM
