break pads
Old Jul 24, 2007 | 12:53 PM
madscientist's Avatar
break pads
i just changed my pads on my o4 evo and the plate on the top in between the pads and the retainer pin is a little loose. is this normal?
thanks
Old Jul 24, 2007 | 12:56 PM
Thegame's Avatar
By plate, do you mean the anti squeal shims? (The silver things that "hook" onto the pins? Or the silver things that sit against the pads?) Did you pump the pedal a few times afterwards? They should all tighten up after the piston pushes against the pad. The top shim will never be "tight," but you shouldn't be able to move it freely by hand either. Have you checked the brake pad how to?
Old Jul 24, 2007 | 01:00 PM
Thegame's Avatar
https://www.evolutionm.net/forums/sh...ighlight=brake
Old Jul 24, 2007 | 01:02 PM
yes it was the top shim thats the answer i was looking for thank you
Old Aug 4, 2007 | 04:31 PM
outbost's Avatar
Sorry, couldn't resist.
break /breɪk/ Pronunciation Key - Show Spelled Pronunciation[breyk] Pronunciation Key - Show IPA Pronunciation verb, broke or (Archaic) brake; bro·ken or (Archaic) broke; break·ing; noun
–verb (used with object) 1. to smash, split, or divide into parts violently; reduce to pieces or fragments: He broke a vase.
brake /breɪk/ Pronunciation Key - Show Spelled Pronunciation[breyk] Pronunciation Key - Show IPA Pronunciation noun, verb, braked, brak·ing.
–noun 1. a device for slowing or stopping a vehicle or other moving mechanism by the absorption or transfer of the energy of momentum, usually by means of friction.
