breaking in new tires??
Old Aug 20, 2007 | 08:48 PM
evobeatsti's Avatar
i just got my first set of new race tires (kuhmo v710 275/40/17). I am going to be doing an autox on them this weekend. i got them brand new from discount tire with no heat cycling or anything. am i ok to just go out and race on them and have a good time or is there some special procedure that i should go through to break them in properly??
thanks for the help, and can someone please explain heat cycling to me?? thanks
Old Aug 21, 2007 | 01:11 AM
spdracerut's Avatar
google is your friend
type in "heat cycling tires"
Old Aug 21, 2007 | 01:33 PM
Neal@tirerack's Avatar
wouldn't hurt to do a couple easy laps the day before, if possible, to bring them up to temp and scrub them in. if you cant, then a couple easy laps before your event will be ok.
Old Aug 21, 2007 | 01:42 PM
evobeatsti's Avatar
ok so i could get to the event, drive them around a little bit before i run, let them cool for a while then i would be fine?? if i bolted up the tires before the weekend, drove around town for like a mile or so then drove home would that be better heat cycling??
Old Aug 22, 2007 | 12:03 AM
spdracerut's Avatar
"wouldn't hurt to do a couple easy laps the day before, if possible, to bring them up to temp and scrub them in. if you cant, then a couple easy laps before your event will be ok"
'couple easy laps' and 'up to temp' can be taken to mean that you don't go and rag on them, but just go take turns at a moderate pace to build up some temperature into them.
'day before' can be understood as some time interval of at least a day before your event.
'if you can't' would account for your hypothetical situation of "ok so i could get to the event, drive them around a little bit before i run, let them cool for a while then i would be fine?? "
Old Aug 22, 2007 | 11:21 AM
evobeatsti's Avatar
i was just wondering how i know if i have acutally heated them up and if i had to acutally drive them hard and waiste some of my autox runs or if i would be fine at the event after i bolted them up to drive down the street and stuff then come back...
Old Aug 22, 2007 | 11:30 PM
spdracerut's Avatar
If you want to see if they're warm, touch them. Warm? Good. not warm? Go take a few more turns. Seriously dude, you can't go through life with someone holding your hand the whole time. People actually go do and try things out themselves; it's called trial and error and you minimize the error by doing research.
Between google and Neal's response, you have everything you need to know and actually more than you need to know.
Old Aug 23, 2007 | 01:33 PM
evobeatsti's Avatar
... i am just asking this because tires are $$$$$ and i dont want to fu*k them up by not doing it exactly right, sorry please keep respones on topic
Old Aug 24, 2007 | 05:37 AM
ghoonk's Avatar
get them warmed up, take them off the car for 48 hours, put them back on, get them warmed up again, and start autocross/track. That's what I've been told and google seems to say the same.
MP Evo
14
Apr 24, 2015 11:41 AM
Smike
For Sale - Wheels / Tires
Apr 22, 2015 03:04 AM
EVOlutionary
Aug 26, 2011 02:50 PM
Jeff_Jeske
Jun 13, 2011 06:54 AM
kekek
11
Sep 15, 2009 08:05 AM
