New motor and oil
Old Apr 17, 2015 | 05:59 PM
MP Evo's Avatar
New motor and oil
I've just finally completed my evo and am going to fire it up tomorrow to get a couple heat cycles in it. Using brad penn break in oil for the heat cycles. My question is which oil does everyone recommend to run for the car. Keep in mind this car will only be driven mainly in spring/summer/and early fall. The machine shop said about running 10w-40. I know a lot of built motor evos run 20-50 what is the main difference between them besides the thickness on cold and once the motor is warm. what does some experienced evo members recommend.
Thanks
Old Apr 17, 2015 | 06:12 PM
moey124's Avatar
is your motor built? and what turbo?
Old Apr 18, 2015 | 12:31 AM
MP Evo's Avatar
Yeah motor is built and running a 6466
Old Apr 18, 2015 | 04:44 AM
meckert's Avatar
Use what the machine shop recommended they know the tolerances and how the motor was put together. I would run a lighter oil under any circumstances until the motor is broken in-- like the 10-40 recommended by your shop--maybe the 20-50 once its run in, maybe.
Old Apr 18, 2015 | 10:05 AM
moey124's Avatar
I agree to what he just said... thumbs up. Use ams oil though the brand.
Old Apr 18, 2015 | 05:18 PM
MP Evo's Avatar
Does anyone have any experience with Rotella t oil? Having trouble getting the primary fuel pump to kick on.
Old Apr 20, 2015 | 06:19 AM
meckert's Avatar
Read the label and get back to us.
Old Apr 20, 2015 | 06:57 AM
gpfury86's Avatar
No one here can help you unless you have the tolerances that the engine was assembled to, but generally it is better to break in on a thinner weight oil and stay out of boost until you put some thicker oil in, but if your engine was assembled with tight tolerances thicker oil will have your pressure too high.
Old Apr 20, 2015 | 07:30 AM
gsrboi80's Avatar
Rotella T6 Syn. Great Oil. I don't think I know a Turbo Subaru owner that doesn't use it.
Run it in my Forester XT and Veloster Turbo. UOA's from both cars are always money. With Blackstone telling me to send another sample back at 8k miles
I never let oil go that long just for my own preference...
I will always use a 10w-30 in the EVO until the motor is rebuilt. I then will follow engine builders recommendation for oil weight.
Old Apr 20, 2015 | 05:48 PM
meckert's Avatar
Not all rotella T=T6...all I have seen is for turbo diesels. Unclear as to why the spec, I assume its a high detergent. Not sure I would be good with a diesel spec oil in my non diesel until I know up front the difference. For that matter-- If you do know and can speak intelligently on the topic, I would appreciate the education as I am sure others would.
Old Apr 20, 2015 | 06:22 PM
Jeff_Jeske's Avatar
I never understood the reference to build tolerances. I mean there aren't that many different bearings and cranks. Shouldn't oil be determined by type of activity/temperature?
Old Apr 20, 2015 | 07:17 PM
MP Evo's Avatar
Yeah I think im stick with the 10-40 and go from there my buddy who helpede assemble everything is saying I should run Rotella t6 and that. Said Brad Penn is cheap oil and just use high zinc because it's basically a cheaper oil and needs the high levels of zinc to keep it from breaking down as easy. Also high zinc was meant mainly for flat tapping cams which our cars don't have but I'm no expert.
Old Apr 20, 2015 | 07:30 PM
Evo-IXse06's Avatar
Use vr1 or bradd penn
Old Apr 20, 2015 | 08:24 PM
sssr20det510's Avatar
I use amsoil zrod has a high zinc content that is good for journal bearing turbos
Old Apr 24, 2015 | 11:41 AM
gsrboi80's Avatar
5w-40 Rotella T6 Syn Blue Bottle perfectly safe for use in your gasoline engine. It does show as a Diesel oil as does M1's 5w40 Turbo Diesel Truck oil
Both have a SM rating which are perfectly fine for your gasoline engine. As I said I don't think I know a turbo Subaru guy/gal that does not run it. As do countless folks here
More info than you can possibly read plus countless excellent UOA's over at BITOG and all over web forums.
You'll never have and issue with Rotella T6 Syn in your car ever
1QYK9
Jul 4, 2013 10:38 AM
Slomo Corey
Member Unresolved Disputes
20
Mar 20, 2012 11:52 AM
abdizzle
13
Jul 12, 2009 07:04 PM
blakevo8
Nov 7, 2005 07:24 PM
