Pulling + Rolling Help (Cracked Paint)
Old Sep 11, 2007 | 10:28 PM
Geesh's Avatar
Originally Posted by dbsears87
Well from what I have gathered +28 is better for the front as it wont rub the inner plastic and it sits farther away from the suspension which some have had trouble with +34 and 265's I guess. On the rear I read +34 is better because it is less likely to rub the quarter panel but then it gets somewhat close to the struts/coilover also. I guess it mainly depends on what tire you run and what coilover you have. To me I believe +34 is a better offset because if it rubs on the suspension or something else you can always add like 3mm or 5mm hubcentric spacers if it came to that. I'm still confused somewhat so I hope somebody chimes in that runs a similiar type of setup.
I heard +28 all the way around works with the suspension and brakes. It clears everywhere. Although the +28 requires fender shaving in the rear. With the +34 it does not clear the brakes up front. Requiring a spacer.
Old Sep 12, 2007 | 05:45 AM
EVO8LTW's Avatar
never mind
SamsonEvoX
Jul 31, 2014 02:23 AM
RATEDX
Jan 7, 2014 02:59 PM
AWM3
West Region
12
Mar 23, 2012 12:40 PM
St1g
37
Mar 21, 2010 01:45 AM
gt40
38
Sep 29, 2007 12:19 PM
