Quick question about width issue...
hey all... just bought a used car, and there are 18x8's on it.... 3 of the tires are 235, and 1 is 225. bottom line - is this an issue? can i drive on it for a bit? i don't have the cash to shell out on 4 new tires; i don't want to replace just 1 or 2...
if they are the same exact diameter you should be ok for now. if you are running different diameter (on an evo at least) it will screw up your diff and you will have to shell out way more than the $$ used to get new tires to fix your diffs...
go to your garage with a tape measure and make sure it is the same diameter as the other 3
ah ****... the 1 tire is 225/40/18, and the other 3 are 235/40/18... this would indicate that they are a different diameter based on the following info from tirerack:
Section Width
Following the letter(s) that identify the type of vehicle and/or type of service for which the tire was designed, the three-digit numeric portion identifies the tire's "Section Width" (cross section) in millimeters.
P225/50R16 91S
The 225 indicates this tire is 225 millimeters across from the widest point of its outer sidewall to the widest point of its inner sidewall when mounted and measured on a specified width wheel. This measurement is also referred to as the tire's section width. Because many people think of measurements in inches, the 225mm can be converted to inches by dividing the section width in millimeters by 25.4 (the number of millimeters per inch).
225mm / 25.4 = 8.86"
Sidewall Aspect Ratio
Typically following the three digits identifying the tire's Section Width in millimeters is a two-digit number that identifies the tire's profile or aspect ratio.
P225/50R16 91S
The 50 indicates that this tire size's sidewall height (from rim to tread) is 50% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 225mm and that its section height is 50% of 225mm. By converting the 225mm to inches (225 / 25.4 = 8.86") and multiplying it by 50% (.50) we confirm that this tire size results in a tire section height of 4.43". If this tire were a P225/70R16 size, our calculation would confirm that the size would result in a section height of 6.20", approximately a 1.8-inch taller sidewall.
Section Width
P225/50R16 91S
P225/50R16 91S
