18 x 9 +34 offset
Old Sep 13, 2007 | 07:19 AM
MyEvoDream's Avatar
18 x 9 +34 offset
Ok, I've searched and gotten opinions and some answers but I just want to be sure before I order these. I'm looking at Volk's 18 x 9 +34 OFFSET. My IX has swift springs on it. I'm looking to get a tire size of 245/40/18. I DO NOT want to roll the rears, which I was told I wouldn't have to, and told I didnt need spacers in the front.
Does this make sense, or should I go with a different tire size, etc. Please let me know of any of you that have this or a very similar set up, I only found a few on here, but none running swifts. TIA, pics would also be appreciated.
Old Sep 15, 2007 | 02:38 PM
seouljahone's Avatar
i run 18x9 + 35 time attacks with 255/35/18 with no rubbing issues at all!!! im lowered just on tananbe gf210's but if you go with a shorter tire height u will be okay!
Old Sep 15, 2007 | 02:45 PM
SHhhhh's Avatar
I run 18x9 +39 with 245/40R18 with no rubbing at all (coilovers)
Pics here:
https://www.evolutionm.net/forums/sh...&postcount=100
Old Sep 15, 2007 | 02:55 PM
Whoop_ass's Avatar
should fit as witht he advan RS which is a 29 offset you need to roll the fenders in the rear if you lowered and this a 35 so means the tire is further in towards the strut if that makes sense
Old Sep 15, 2007 | 03:07 PM
savaho's Avatar
I run 18x9.5 +34 Volks with 265/35ZR18 Dunlop Dirreza Z1s on Stance coilovers. I think you should be ok with 18x9 however I'd recommend getting 255/35-18 tires. You aren't too low with the swifts so this setup should be fine.
Old Sep 15, 2007 | 10:17 PM
dbsears's Avatar
^^Didn't I read you run 5mm spacers, which ones are you using. Is that front and rear you got spacers also? Also do you rub at all with that setup. Thanks
