Tein EDFC vs Tanabe TEAS
Tein's EDFC feature where you get to choose the damper of the shocks from the driver's seat is really a good feature. When I was riding in my friend's STI with the Tein Coils w/ EDFC, he was testing out thefeature for me but the response for the damper seemed a little too laggy.
I was thinking of getting the EDFC but I've been hearing good feedbacks about Tanabe TEAS. Far as responsive wise, I heard that the TEAS reacted much faster and the damper was lot more noticeable than the EDFC.
Anyone actually have the TEAS on the Evo's?
I don't see how the response from the damper seems laggy.... a motor is turning the adjustment mechanism on the shock. those adjustments are effective as soon as the next piston travel inside the shock, where exactly does the lag come in? Unless the adjustments aren't actually effective..........
Also, not for nothing, but I'm not sure I want a computer kicking my damping down to a progressive, soft damping level when I'm diving into a corner at 80mph on the track.
I've used the EDFC with Flex dampers on my old car, and it was a nice toy to play with on a track day (and grocery saver when going over speed bumps), but the settings weren't consistent enough that I would have trusted the computer to do it for me automatically. No personal experience with the TEAS though. If I were to buy another set of coilovers, I'd spend the extra money for the electronics on better shocks instead, ultimately you get more out of it that way.
"real-time" means it changes the shock settings automatically based on some monitored parameter. For example you can monitor vehicle speed, and it will automatically make the shocks softer for high speed straights, and then harder again as soon as you slow down for a turn. (Just an example, I don't know what parameters the TEAS actually looks at).
Not real-time means you (the driver) need to push a button to change the shock setting.
Yeah its based off of the VSS (Vehicle Speed Sensor), their website has alot of info actually, duh
http://www.tanabe-usa.com/coilovers/TEAS.asp But still wondering if anyone has run they system or has a first hand review on the product.
We use somewhat the same motors in the lighting we build.. they are somewhat fast but doesn't move lighting speed... I would rather have the slow speed to see how it reacts when you are changing the setting...
Rolling works fine (and is pretty helpful for fine tuning things on the track). The internals must not be a pure orifice realign or it would seem like you could lock your shock out between positions. This definitely doesn't happen.
What exactly does this mean? Can you explain it in laymen terms?
I think he means that the internals arent super "tight" together if that makes sense so they are not as accurate but allow for on the fly adjustment.
thats why high end companies like DMS, Moton and Penske do not offer such systems.
The EDFC uses stepper motors on top of the shock adjustment knob. It is indeed adjustable in real-time as you move, it is not active however. Similar system are available from Cusco and now GReddy (saw it at SEMA).
eastcoastoutlaw
Oct 3, 2013 11:10 AM
explicitcarclub
21
Aug 2, 2013 09:30 PM
Trustz
Dec 27, 2006 08:15 AM
Evo H8
35
Oct 16, 2006 05:54 AM
