Whiteline Steering Precision Kit Instructions
Old Feb 9, 2013 | 01:57 PM
  #31
fireroasted's Avatar
Originally Posted by MRLancer05
Im not changing by ball joints so I think I'm gonna try and pull the whole strut-knuckle-arm assembly off all together?
Not sure I follow that comment. For just the steering kit, I believe you are best dropping the subframe out, then it takes just seconds for the kit itself. Then reinstall the subframe. If its never been out you will probably find a couple of washers, nuts, and other crap wedged up in it anyway. The location is kind of a collector for things you drop behind the engine when working. Having it out gives you a real good understanding of how everything works and is laid out.
if you haven't changed the front sway bar yet, I would encourage doing that during the job. Its totally worth it even if you just DD. I suggest the H&R bar, but it probably doesn't really matter.
Old Feb 9, 2013 | 04:33 PM
  #32
MRLancer05's Avatar
I just meant that I'm not gonna separate the lower arms from the knuckle assembly. My car was from up north and I think the previous owner didn't have a clue about what they were doing so I find a lot of screwed up stuff on my car. I honestly in fear of turning bolts on the exhaust. I've got a 26mm WL sway bar to go on as well.
I autocross my car monthly at local events and it definitely throws its weight around, of course that was with two blown struts up front. Now I have Bilstein HD's so I'm sure that will help a little.
TommiM
18
Jul 11, 2018 12:57 PM
Casey Robertson
Jul 17, 2016 05:17 AM
rawkus
Jul 1, 2015 06:51 AM
OverBoostedEvo
Apr 9, 2015 01:14 PM
Touge Factory
Evo 'For Sale' Suspension / Brakes / Handling
285
Mar 7, 2013 02:04 PM
