powder coat MR BBS's
Going to lower it about another 0.5" around, then align and camber it.
Came close to getting the lip polished but was quoted $240 for it and would rather buy some volks if spending all that money.
This way I can do a vinyl lip in red with custom text or anything I want and its temporary.
Originally Posted by lacartus
It really depends on the material you are powder coating. I believe most wheels use 6061-T6 aluminum, which is solution heat treated (elevate to a temperature, which is over 350F, and quench (cool quickly)) and artificially aged (elevate above room temperature, but below the previous solution temperature and let it sit there for a while) to strengthen the aluminum. Huh? So how does heating my wheel to 350F for a while affect the strength of it? The more time you heat the aluminum over its transition temperature, the more you undo the heat treatment and weaken the wheel. There are tables that summarize this (none handy, but Mil. volume 5 comes to mind), but you have to know what Al you are heating. To be safe, I'd suggest coating with an epoxy resin that softens (goes from powder to the smooth coating) at ~275F; definitely below 350F.
