Most Comfy coilovers? as soft as MR shocks?
Old Nov 6, 2007 | 06:32 PM
twinturbozs's Avatar
Im looking for some soft/streetable coilovers. I know it sounds like an oxymoron, but id like to find a set of coilovers that ride as smooth as my MR shocks. I have lowering springs on my MR now, but i need more adjustability (lowering and camber adjustments).
My old bones cant handle the jarring ride. Even the stock GSR suspension is too stiff for me. I dont want coilovers that will start clunking after a few thousand miles. throw some suggestions up. thanks
Old Nov 6, 2007 | 07:01 PM
TTP Engineering's Avatar
Megan Street units. We have two sets in stock.
Old Nov 6, 2007 | 07:51 PM
GTWORX.com's Avatar
Bilstein PSS9....not much else. Maybe custom springs on KW V3's. I wouldn't mess with anything from Japan or China/Taiwan since you're gonna want travel and lots of it. That and quality damping.
Although, if you just need camber adjustability, why not just get camber plates on your MR shocks? What do you need height adjustability for?
It's going to be very difficult to match the ride quality you have now. I'd be worried about screwing it up personally and going to coilovers with 8k/6k rates with short travel is not going to give you even close to the same ride quality that your MR Bilsteins give you.
Why do you want coilovers?
- Andrew
Old Nov 6, 2007 | 08:46 PM
The current springs offered for the MR bilsteins dont drop the car enough for my taste. Also my front camber is not symmetrical. I can only get -1.8 and -0.5 on the fronts. I can use camber plates with my Bilsteins, but they will raise the front up 1/2" which is counterproductive to my needs.
I'd like to be able to occasionally track the Evo too.
Old Nov 6, 2007 | 08:58 PM
JDMCT9MR's Avatar
I have the HKS Hiper Max RS and love em!
Old Nov 7, 2007 | 01:30 AM
dbsears's Avatar
Ohlins or KW3...best ride your going to get with performance for the $$$. The bilsteins have a nice ride...performance wise you will only get so much out of them. I would go with KW3 or the new Ohlins which will ride maybe a tiny bit firmer but give you good adjustability and quality damping. Cant say the same about some of the JDM japanese coilovers that ride frozen struts on a washboard roads .
Old Nov 7, 2007 | 01:32 AM
Speed Element's Avatar
We have a few kits in stock that you are welcome to stop by and check them out.
I highly recommend the Endura Tech coilover kits for daily driving and occassional track use.
The Endura-Tech coilovers feature:
• A twin tube structure
• Come with front pillow ball upper mounts with camber plate adjustment
• 10-way dampening adjustment
• Lower bracket height adjustability prevents having to adjust the spring
seat offering maximum suspension travel
• Front Spring rates are 7kg (392 lbs./in)
• Rear Spring rates are 5kg (280 lbs./in)
Shock Dyno Graph: http://www.speedelement.com/images/p...ra-techevo.pdf
Old Nov 7, 2007 | 01:54 AM
Wicked E's Avatar
Speed-
How do those compare to the Jics and Ohlins?
Cheers-
Erich
Old Nov 7, 2007 | 06:24 AM
cfdfireman1's Avatar
Ahhh what?
Take your car to a place that knows how to do an alignment. There's no way you can only get -0.5 on one side with the camber bolts in the right position. arrows must point out.
Old Nov 7, 2007 | 08:48 AM
atombomb33's Avatar
EvoM Community Team
I have BC Racing BR-type coilovers and when set to full soft they ride very nicely. Much more comfortable than stock GSR or MR set up because the damping on the BC coilovers is perfect for daily driving. And, when I want to drive spiritedly or hit the track, set them to full hard and they feel very stiff with minimal body roll. You can get these for around $900 shipped.
Old Nov 7, 2007 | 08:54 AM
DaWorstPlaya's Avatar
- Andrew
Agreed! Having riden on KW V3, Ohlins Sportlines and Bilstein PSS9. I can honestly say Bilstein PSS9s are the softest ones to go with. Softer than the stock EVO suspension, right up there with the MR Bilstein in comfort ...
Old Nov 7, 2007 | 09:04 AM
Evogasm's Avatar
ive rode in an Evo 9 with Megan coilovers,pretty smooth ride,and they are affordable too!
Old Nov 7, 2007 | 09:55 AM
GTWORX.com's Avatar
Somethings definitely wrong then that I'd fix....camber plates would be a band-aid for that camber problem. Unless you've been in a major front end accident. See if the lower strut mounting point upper bolt holes have their arrows pointing in different directions on both sides of the car.
I'm thinking Bilstein PSS9 for your needs....but Swifts on MR Bilsteins plus Whiteline camber plates (do not raise car if at all) would be a great set-up too.
- Andrew
Old Nov 7, 2007 | 02:03 PM
scottlowe's Avatar
I would strongly recommend HotBits, which give a much more comfortable ride than standard, yet really perform when the car is pushed.
www.hotbits.org
Old Nov 7, 2007 | 07:52 PM
mandy1's Avatar
if you want a smooth quality ride you should get at first a cadillac or if you still want mitsubishi get a diamante or galant. damn i dont understand people! i have tein super street with edfc and love them,when i want a smooth ride then i use my Hyundai Sonata.
