Coilover of choice - explaination
Old Nov 29, 2007 | 12:11 PM
  #31
CliveW's Avatar
Originally Posted by Dave Mac
Sorry Clive, I did not mean to come across arrogant. I forgot my smilies
Andrew knows I'm a really arrogant bastard.
No Problem dude
Old Nov 29, 2007 | 12:22 PM
  #32
hokiruu's Avatar
EDIT: Sorry OT.
Old Nov 30, 2007 | 09:29 PM
  #33
UDLOZ2's Avatar
I that price range what do you guys think of the Megan racing set up? any good?
Old Dec 1, 2007 | 11:39 AM
  #34
hokiruu's Avatar
Most of these coilovers are a tier above the Megans in terms of price and quality. Megans are more comparable to Helix, Apexi EXV, Greddy, as these are all the same as/manufactured by BC Racing.
Old Dec 1, 2007 | 12:09 PM
  #35
E7R's Avatar
E7R
Originally Posted by h22gordo
Wow! All these know-it-all's!
RalliArt coilovers are made by BILSTEIN!!!!!!!!!! Not KW, or Koni.
Read more carefully next time but ill explain it just for you:KW shocks are made by KONI,but i think that you know about that..........
On thread: TANABE / JIC / or EXE-TC
Old Dec 1, 2007 | 12:41 PM
  #36
hokiruu's Avatar
I haden't heard of Exe-TC until now. They look very nice and well designed. It also appears that they cost almost twice as much as the most expensive of the coilovers mentioned in this thread.
Old Jan 24, 2008 | 05:08 AM
  #37
wartownracer's Avatar
i read earlier in this thread someone mentioned that a good set of shocks and springs would be better than coilovers cause they would be more consistant. Can someone elaborate on that. I mean this is getting a little confusing to me now, as i am also lookin for a good street/track coilover.
Old Jan 24, 2008 | 05:34 AM
  #38
Dave Mac's Avatar
What is most important to you; daily ride characteristics or blazing around a track? Depending upon what your priority is the answer will be different. The VERY best bang for the buck would be the Ohlins DFV's for street or track, then Bislteins-if you are looking for good road manners. The KW's are not as nice on the street but have a slight edge on the track over the Bilsteins.
If you are not inclined to mess with coilovers and do corner balancing you can use a good spring/damper setup. The best example would be GTWorx Evo springs on Ohlins replacement dampers, but you be looking at the same price as a set of low-mid price coilovers. Another VERY good setup for daily driving and some track would be MR Bilsteins on GTWorx springs.
I hope this helps you refine your search a bit more.
Old Jan 24, 2008 | 06:20 AM
  #39
GTLocke13's Avatar
Which Koni's do they use? 8611's? I'm surprised I hadn't heard that before.
I'm also surprised no one has mentioned these yet:
http://zzyzxmotorsports.com/products/coilovers/emsport
DA Konis for the price of KWs. Which I guess sounds like DA Konis for the price of DA Konis now... Time to do some research.
Edit: Bzzt.
Originally Posted by KW Website
KW suspensions sports shock absorbers are produced in cooperation with the major series manufacturer AL-KO...
Here's the AL-KO website: http://www.al-ko.es/english/catalogo.htm
Pretty sure that's not Koni.
Old Jan 24, 2008 | 07:21 AM
  #40
Dave Mac's Avatar
From what I understand KW's have SOME dampers that were engineered with Koni parts and some (most) with al-ko. The only company that has a direct Koni connection (from what I've seen) is AST. The connection comes in the form of the owner of AST working for Koni for years. I'm not 100% on this but again, that is what I've seen in my research.
GTLocke13-
I can't wait to see your BSP Evo run some time this summer!
Old Jan 24, 2008 | 07:26 AM
  #41
GTLocke13's Avatar
GTLocke13-
Unfortunately, you'll have to wait a while longer. I'm co-driving an A-Stock Solstice this year. The Evo won't make it's BSP debut until next season.
Old Jan 24, 2008 | 08:18 AM
  #42
GTWORX.com's Avatar
KW used Koni dampers a LOONG time ago.....ancient news.
AL-KO makes a lot of OEM "sport package" shocks for a bunch of cars.
Hard to go wrong with either zzyzx or KW....both are high quality, double adjustable, have great valving etc. They're going to beat a lot of the super short travel, poorly valved, Japanese and Chinese coilovers.
- Andrew
Old Jan 24, 2008 | 08:19 AM
  #43
hokiruu's Avatar
Any adjustable suspension is only as good as how it is set up. More options may just be more opportunities to set it up improperly, and it doesn't matter if it's a $900 or $10,000 suspension, if it's set up wrong, it's not optimal, and the adjustments are not helping you until they are correct. Also, many of the lower end coilovers (including some that cost up to $2k) have been said to have inconsistent results from their adjustments accross the unit, and across the set on a shock dyno. Regarding consistency, if you were racing and trying out different setting on each run, and probably running a different time each lap you would be blurring what is the results of your driving and what is the result of the suspensions settings. With a "install it and leave it alone" non-adjustable shock/spring setup, you would be sure that it is your driving that is affecting your times. Of course, once coilovers are set up properly, there are few occasions to change the settings, and it is the same after that.
Old Jan 24, 2008 | 08:28 AM
  #44
hokiruu's Avatar
Oh I forgot to update. I ended up getting some JIC FLTA2 because they were take-offs from the Showcase Evo. and I got them for less than the price of BC Racing coilovers. They have some unknown custom spring rates. If they were good enough for good drivers like andy Lieber and John Tak to do well at Nationals, they will be good enough for me to learn on.
Old Jan 24, 2008 | 08:33 PM
  #45
EJEvo's Avatar
Truer words were never typed... +1.
