Squeals When Braking to the Left?
Old Nov 9, 2007 | 06:59 AM
fuzzychi's Avatar
This is very odd I'm guessing it has to do with my brake pads but it only happens when I brake while turning to the left. As I press down and turn even ever so slightly to the left my brakes squeal very very loudly. It doesnt happen if I'm going straight or turning to the left while braking. Any ideas? I'll probably take off the front tires and inspect the pads and rotors soon.
Old Nov 9, 2007 | 03:10 PM
fuzzychi's Avatar
Old Nov 9, 2007 | 09:42 PM
fuzzychi's Avatar
Old Nov 10, 2007 | 09:02 AM
fuzzychi's Avatar
Old Nov 11, 2007 | 11:45 AM
fuzzychi's Avatar
Old Nov 11, 2007 | 02:44 PM
ty423's Avatar
get some brake cleaner and spray it down...
Old Nov 13, 2007 | 11:56 AM
JDMCT9MR's Avatar
Strange.My brakes will squeal a bit when Im braking very slowly.
Old Nov 13, 2007 | 05:20 PM
Sluggo's Avatar
same here
Old Nov 13, 2007 | 05:33 PM
YtDiamond05's Avatar
Mine squeal alot also when slightly braking, especially when in reverse.
Old Nov 13, 2007 | 05:35 PM
GTLocke13's Avatar
Take you wheels off. Check everything. Check that the calipers are tight. Check that the rotor is seated correctly. Check that the pads are seated correctly. Check that you're not missing a retaining pin. Check that the little spring retainer thingy is still positioned correctly. You get the idea.
Then, if you still have the squeal, go buy some caliper lube and follow the instructions here:
https://www.evolutionm.net/forums/sh...ight=brake+pad
In particular the bit about where to lubricate your pads.
Old Nov 13, 2007 | 05:51 PM
Btung4231's Avatar
i dont know about your particular problem, but the brakes on the mitsu's are sport breaks, thats one of the things that comes with buying a sports car, the breaks squeal!
