Lowering Evo Alignment Kit
Align anywhere except there.
Which coil-overs? I am guessing ones without a camber plate. Did they install the camber bolt correctly? Using the -2 bolt selection and -1.75 in lower, you should see a true camber of -2 or more.
I recommend getting -2 to -2.5 up front and -1 to -1.5 out rear. Zero toe, zero thrust angle.
Mitsu keeps saying it's the coilovers that are the prob and C8 is saying that there should be no prob..... HELP!!!! Not gonna buy new tires till I get this figured out.
Rear is simple. The camber is changed by one of the bolts on the rear arm. Its even indexed with dash marks - if your dealer cant do an alignment - go somewhere else.
Thanks for the help. I will take it somewhere else and let you know how it went. If they have the same problem as Mitsu and say that the range is not enough to align, how should I proceed after that?
CaptainSquirts
May 9, 2017 01:03 AM
TxFAkuma
Feb 17, 2017 03:45 PM
XtoEvolution
29
Sep 2, 2008 12:04 PM
phatty04oz
May 17, 2004 05:31 PM
