staggered offset question
Old Dec 21, 2007 | 03:25 PM
diiirk@AwdMotorsports's Avatar
Ive been trying to find an easy way to fit a set of enkei rpf1's on my car. The 18x9.5+15's will fit with alot of work. Mainly in the rear. So im thinking that since the +38 has the same face as the +15, im wondering if i can run the +15 up front and the +38 rear. I see alot of people running the nt03's in the +27 with a 12mm spacer up front, thus bringing the offset to a +15. The nt03 needs some fender rolling in the front and rear.
I think this would be a better option rather than risking serious rubbing and possibly ruining my rear 1/4 panel trying to roll and pull it out to fit the +15. I may also run a 10mm spacer in the rear to try to even it out. i think a wheel sticking out in the front with a wheel sunk in the rear doesnt look right.
Assuming that the faces are the same, will there be any problems running this setup? I will be on coilovers and not too low. Aside from tire rotation is there any downside to running staggered offsets? thanks
Old Dec 21, 2007 | 06:35 PM
4Trouble's Avatar
Should be ok as long as you keep the tires same size for all four.
Old Dec 21, 2007 | 06:38 PM
DarksideEng's Avatar
They will be fine, but you are right about them not looking right. The fronts will be very aggressive, where as the rears will be an easy fitment. Your spacer idea is good though, I would do a 10-15mm though. If you run enough camber, you can get the +15 to fit in the rear. Your 100% positive they are the same face on both offsets though?
Old Dec 21, 2007 | 07:23 PM
i am not 100% sure yet, ive heard from a few people that they are the same, but i contacted vivid racing and they are working on finding that out.
Old Dec 23, 2007 | 08:52 PM
Mike@JTuned's Avatar
What he said.
Different tire sizes will cause strain on the AWD system. Aggressively low offset wheels will cause strain on the wheel bearings.
Blue91lx
26
Jul 11, 2012 12:58 PM
CWiLL
For Sale - Wheels / Tires
Oct 7, 2011 09:20 AM
555R
Apr 22, 2011 09:58 AM
eliminator 429
15
Mar 23, 2010 10:41 AM
blueprint
34
Mar 30, 2009 12:28 PM
