Enkei PRF1 17x9 offset?
Subscribe
Dec 31, 2007 | 05:11 PM
Went to les schwabs today to have my RPF1 17x9s put on with the 35mm offset and they said they wouldn't fit. WTF?! I know the 35mm works on 17x8 so what should I need on the 17x9? Any help greatly appreciated..I want rims NOW lol...btw they are 15.9 lbs. What are the stock evoVIII rims weigh in at???
Reply 0
Dec 31, 2007 | 05:28 PM
I would give this site a try. http://www.1010tires.com/WheelOffsetCalculator.asp If you own the wheels, have you put them on to see if they will clear the brakes?
Reply 0
Dec 31, 2007 | 05:41 PM
He says they didn't clear the brakes but I know of one other evo that ran this same rim and size and they worked...What about NP03s? I like those as well.
Reply 0
Dec 31, 2007 | 06:06 PM
Maybe the other guy used spacers to compensate the difference. Also, I'm not sure of what wheels you are referring to. When it comes to new wheels, I always will go to tirerack because they guarantee the fitment and they have plenty of rims to choose from. But if you are looking for a specific wheel, I would go straight to the manufacture.
Reply 0
Dec 31, 2007 | 06:18 PM
They won't fit because you have to run a 20mm spacer up front. Do your research next time to save the hassle of bringing the rims around the tire store
Reply 0
Jan 2, 2008 | 08:22 AM
what offset is required to clear the stock brembos..?
Reply 0
Jan 2, 2008 | 10:31 AM
Everyone with those needs a 15-20mm front spacer for the spokes to clear the front Brembos. Keep in mind this may not apply to other 35mm offset wheels.
Reply 0
Subscribe
