Agressive Suspension
Thanks Andrew, That helps a lot. I was thinking of just getting the MR Bilstiens with some drop springs, but I would like to have the option of raising and lowering the car for the harsh Chicago weather, and having an adjustable spring rate.
I'm still not sure. No one else is saying what they use. C'mon people.
How much do the GTWorx springs go for?
- Andrew
There are many advantages and disadvantages to coilovers. And you shouldn't lump all coilovers in the same category. Some are awesome, and some are total crap that do not handle better then stock and make tons of noise and bounce around like crazy. I'll leave it at that.
- Andrew
- Andrew
https://www.evolutionm.net/forums/sh...ruts+coilovers
The drawbacks of coilovers are that they MAY be noisy, harsh riding, and require increased maintenence. Generally, the more you spend, the better they get in this regard (not counting motorsports level coilovers which can go for 5k per corner.....)
Advantages of coilovers are the adjustability, tuning ability, lighter weight, and the ability to support much higher spring rates then stock. And less shock fade.
https://www.evolutionm.net/forums/sh...6&postcount=17
- Andrew
This thread had some good info on fixed struts vs. coilovers:
I posted some thoughts on major suspension brands here:
- Andrew
- Andrew
Thanks for all your help.
Now, the hardest part? Picking.
All right. I know it's been a while but I just heard that the skunk2 springs were pretty badass. I'm not saying that they are or arn't, but I do want to know if anyone has had experience with them.
I've had a lot of skunk2 suspension stuff on my si and it was all awsome, especially the camber plates.
Anyone?
Anyone?
