painting wheels
Old Feb 3, 2008 | 04:51 PM
SuprEVO's Avatar
painting wheels
hey can anyone suggest what kind of paint to paint the stoock bbs wheels with or what i can use to change the color of them. thanks!
Old Feb 3, 2008 | 07:34 PM
bluehippo's Avatar
powdercoat them or it wont last long
Old Feb 3, 2008 | 08:09 PM
igo4bmx's Avatar
bad statement-
if you paint them properly you won't have issues.
ChuckP's Avatar
vht high temp wheel paint. thats what i used.
Old Feb 3, 2008 | 08:12 PM
igo4bmx's Avatar
duplicolor wheel paint is good too.
Old Feb 4, 2008 | 09:24 AM
James@DSR's Avatar
In a high durability enamel will work, duplicolor wheel paint is good too. Powder coating is very good but ANY kind of painting, including powder coating, needs to be done correctly or it will either look bad, chip later, or weaken the spokes (myth). Always do it in a controlled temperature environment 65-75 degrees. Make sure you put the right amount of clear (depending on how many coats you put on) so it won't chip or scratch easily. You dont knwo how many ppl I seen paint their wheels inproperly and not to mention they dont even put any clear coat! And they wonder why the next day they have fat paint chips on the lip. Do ti right the first time!
James
Old Feb 4, 2008 | 05:15 PM
mrich82's Avatar
I decided to paint my wheels vs powdercoating because if your powdercoating chips you can't really fix it... but if your paint chips its easy to fix.
I used the Duplicolor wheel paint and it turned out pretty good.
Old Feb 4, 2008 | 05:20 PM
Smike's Avatar
Powercoating also could change the molecular structure of the metal in the rims (make it brittle).
Just take them over to a good shop and have them prof. painted with base and clear.
Old Feb 4, 2008 | 05:48 PM
shunderwunder's Avatar
The temperatures used in standard powdercoating (not high temp) will not do anything to the structure of the wheel. Wheels actually get close to those temps under track conditions anyway. However painting works just as well, is less expensive, & can be done by yourself. Many factory wheels are painted so durability is not really a problem. As stated the most important thing is to prep the wheels correctly & sand them completely so the paint will stick.
Old Feb 5, 2008 | 04:46 PM
SuprEVO's Avatar
now when i get them powder coated or painted wont it chip around the lip of the wheel when i go to have the tires put on?
Old Feb 5, 2008 | 05:14 PM
SuprEVO's Avatar
also should i sand the wheels or have them sandblasted and then cleaned with wax and grease remover
Old Feb 5, 2008 | 06:25 PM
ChuckP's Avatar
If you have access to a sand or bead blaster do that. If not just use some gritty steel wool and you will be fine.
Painted wheels are going to chip regardless, but a good prep job will help a lot.
Also, mud flap and painted wheels is a big non-no, i learned the hard way.
Old Feb 6, 2008 | 05:18 AM
turbo271's Avatar
Where you guys buying your paint?
Old Feb 6, 2008 | 09:45 AM
ChuckP's Avatar
Summit Racing.com
Old Feb 6, 2008 | 09:51 AM
red evo8's Avatar
says who , you? I think not.
RATEDX
Jan 7, 2014 02:59 PM
assembeldbygod
22
Mar 4, 2009 04:36 AM
wj4
Jun 24, 2006 04:10 PM
twan
Aug 11, 2005 07:16 AM
CombatCQB
Nov 26, 2003 09:36 AM
