Problem! And mitsu is being dumb.
Hey guys need some help, recently my car went in to get a stock clamp back on the inatake tube going into the throttle body i beleive ( other one snapped off somehow ) Anyways, as im there a mechanic notices that my 2 front tires are very warn on the INSIDE of the tire, district manager is being a jackass and saying they wont give me new ones, im still fighting though. The car went in to get looked at and they said they couldnt find a prblem? Does anybody know what is causing this? 6K on the car!!!
Have you rotated the tires? The Evo has negative camber from the factory so it will wear the insides of the tires. Rotation and alignment helps them last longer. Alignment is covered under 12,000 miles - If it needs one. The rear insides wear more than the fronts normally, did you just rotate? If you want a good alignment you'll have to probably take it somewhere other than the dealer. Excessive toe will cause that type of wear as well.
I went and got my car inspected 2 weeks ago and i had to purchase new front tires and my car only had 8,600 miles on them. Outside of tires were completely bald. Then the service dude said it would be $350 mounted and balanced. I like an idiot thought it was for both(knowing in the back of my head that was really cheap) but it didnt cross my mind that it was per tire until I got the bill!! To say the lest it was a very expensive trip to the dealer.
I think they will replace the tires too if it was before 12,000 miles or 12 months whichever comes first. The dealer asked me if I wanted to change the tire, but I declined since I caught the abnormal wear pretty early at 7,000 miles.
I'm not sure. Service guy said i'm looking i didnt have to replace them all and sooner. I bought my car brand new in August of 2007, the car has little over 9,000miles on it. And I lucky i haven't had to replace tires earlier???? I dont get it, and they wont warrenty them or anything.
Search is your friend,
SEARCH alignment specs
https://www.evolutionm.net/forums/sh...lignment+specs
https://www.evolutionm.net/forums/sh...ad.php?t=18433
The second link has the OEM specs, note the factory toe settings on the rear.
As far as warranty replacement on tires... from Mitsubishi? Are you kidding?
I put tein springs on and put off the alignment for 3 months because i couldn't find a place that could get the car up the ramp, long story short, by the time i got around to it the advans were TRASHED. so i need new tires as well. ALIGNMET is SO important don't screw around. put up the money. its better than ruining a g's worth of rubber.
MY advans only lasted 8k miles......(fronts havin the worst wear). Tires would fall under the catogory of "Wear and Tear" , just like the clutch and brake pads...............hope everything works out
Camber will not chew up the inside shoulder. Camber wear starts at about the middle of the tire.
Excessive toe will eat tires. It generally wears off just the shoulder.
10k is about average for the stock Advans. 15k is possible if you don't drive hard. I've heard of 20k, but if you get that you should have bought a Crown Vic instead.
Mitsu will not give you new tires.
