Question about hawk ceramics
Old Apr 2, 2008 | 05:34 AM
xexitenglishx's Avatar
I just installed the ceramics on my front brakes. The hawks came with a shim already on them and i took other peoples advice on here and put the stock shims on as well. Basically I put 2 shims on per brake pad and the brakes have this horrible screech with they are warmed up. It ever screechs at high speed if i dont hit the brakes somewhat hard. I did use a ton of brake pad paste in between the 2 shims and all over the pad and i bedded them but it still makes noise. Should i not have used both shims? If not which one should i use the hawk ones which cover the whole pad or the ones off the stock pads which only cover half the pad? Thanks for your help guys.
Old Apr 2, 2008 | 05:41 AM
Neal@tirerack's Avatar
Let me see what tech says about this and I'll let you know.
Old Apr 2, 2008 | 05:55 AM
thank you very much
Old Apr 2, 2008 | 08:52 AM
This is what they suggest,
Use hawk shims only. Did they use new rotors or resurfaced at minimum? If it is making a screeching noise it is possible that the pads were overheated and glazed the rotors.
Old Apr 2, 2008 | 09:20 AM
ill give it a try. I dont think i over heated the pads because i was only bedding them from 45mph to stop about 6 or 7 times. I temporarily had "pep boys" pads in because my brake were worn down to the point of no return and i didnt want to ruin the rotor. Maybe they glazed the rotor. How would i go about unglazing them? Could i lightly sand the rotors or should i try to rebed them?
Thanks alot neal
Old Apr 2, 2008 | 03:44 PM
Ok i tried it with the hawk shims only. I am still getting the screeching sound. After i took the pads out i think i narrowed the problem down. My rotors have a pretty large lip on the edge, i guess the stock pads dont reach out all the way. The pads now have a groove on the edge on all 4 near the edge. Should the lip wear down faster then the other parts of the rotor and eventually the screeching will stop or should i get the rotors turned? Thanks for the help
Old Apr 3, 2008 | 05:04 AM
anyone?
I tried lightly sanding the rotors and pads and rebedding them but they still squeak. They are quiet until they heat up, once they heat up they dont stop squeaking unless i brake really hard.
Old Apr 3, 2008 | 11:22 AM
From my tech dept...
He needs to have the rotors turned to even up the face. Its always best to resurface the used rotors when installing new pads.
Hope this helps.
Old Apr 3, 2008 | 02:11 PM
Thanks Neal. Apparently you are the only one that knows about brake pads and rotors haha
Old Apr 3, 2008 | 02:20 PM
Np at all!
Old Apr 4, 2008 | 09:23 AM
RoBear's Avatar
No that's service! Way to go Neal.
Old Apr 4, 2008 | 09:33 AM
Raptord
26
Dec 11, 2011 02:04 AM
mike127
Aug 25, 2008 07:43 PM
vicbdn
12
Jun 23, 2008 11:45 AM
Schuyler
10
Dec 17, 2007 11:45 AM
Girodisc Martin
Mar 7, 2007 09:50 PM
