View Poll Results: Will you mod for better suspension or more power first?
Suspension - I want more cornering grip!
15
45.45%
Power - Must have more power!
18
54.55%
Voters: 33. You may not vote on this poll
suspension or power?
Originally posted by sccavee
You may want to look at my sig? I race open wheel formula cars. What do you race?
Some good info here
I've been leary of taking on the suspension at this point because I'm not sure I've found a solution I like yet. As for wheels and tires; yeah, those will be addressed. I want to go after the bigger replacement items first; still using the stock wheel and tire combo as baseline. (Did that make sense?) Basically I want to get the suspension where I want it before I start playing with tires and rims.
I know my first mod should really be brake pads and hi-temp fluid; I cooked the stock set-up pretty well on my first track day. Since then I've changed my breaking to stress the stock system less on track days. I've done another 5 or so without re-cooking anything.
It looks like my first mod will be power, though. I've ordered Shiv's turbo back stage one kit. I'm hoping it shows this week.
I've been leary of taking on the suspension at this point because I'm not sure I've found a solution I like yet. As for wheels and tires; yeah, those will be addressed. I want to go after the bigger replacement items first; still using the stock wheel and tire combo as baseline. (Did that make sense?) Basically I want to get the suspension where I want it before I start playing with tires and rims.I know my first mod should really be brake pads and hi-temp fluid; I cooked the stock set-up pretty well on my first track day. Since then I've changed my breaking to stress the stock system less on track days. I've done another 5 or so without re-cooking anything.
Are you going to try the 93 octane maps on Holiday gas? Or are you going to play it safe with the 91 octane?
Are you installing everything yourself?
Fair point! I'm not sure of where I want to go with the suspension, though.I'm currently trying to decide between the JIC coilovers or a set of Espelir super down springs (Link: https://www.evolutionm.net/forums/sh...threadid=26440 ) and a set of Koni's. Any opinions?
EClark11GTS
May 23, 2016 10:31 AM
