FQ-400 Boost/Power/Torque Curve
Has anyone ever plotted out the Boost Curve for a stock Evo X FQ-400? I also wouldn't mind seeing the Power/Torque curves plotted either. Any reference to those would be interesting. I'm curious as to exactly how much the UK Mitsu Engineers are willing to push the boost across the RPM band.
Crazy, I happen to do a search today to see if anyone has posted the stock boost curve of an Evo X FQ400. I couldn't believe it. The number one hit on Google is my own post with no response almost a year to the day. Anyone?
It's just such a rare car and the fact that they don't make it available here in the States means chances are about one in a million you will ever get an answer. Then again people do get struck by lightning or win the lotto, you never know.
I bet there aren't a lot of FQ400 owners. 80,000 USD is a lot of jack for an Evolution, even as good a car as the FQ400 is.
Though if I *had* $80k for a car...yeah, *I'd* be dumb enough to buy one and ship it over from the UK.
You can make a FQ 400 for a lot lot less. A COBB 400S kit, a Alcon big brake kit, and a few other mods; boom you have a FQ 400 more or less
Agreed. I sure would like to know how much boost the British Mitsubishi engineers are willing to run in that thing...with a warranty! I'm at around 400 hp now, but I'm hovering around 24 PSI. It would be nice to see if the 400 hp could be obtained with less boost.
Here's the parts list from AutoBlog with my comments
. Based on the parts below, how much boost would you guess they are running to get 403 hp at 6500 RPM and 387lb-ft of torque at 3500 RPM?
High-flow fuel injectors (I was surprised this was necessary)
New turbo with low friction bearings (Is it the same dimensions as the USDM Stock?)
High temperature turbine that Mitsubishi insists will keep turbo lag at bay (General goodness for longevity)
New intercooler (Makes sense)
A new ECU works its binary magic (Can't touch Tephra
Three-inch stainless steel exhaust (That's easy)
. Based on the parts below, how much boost would you guess they are running to get 403 hp at 6500 RPM and 387lb-ft of torque at 3500 RPM?High-flow fuel injectors (I was surprised this was necessary)
)Three-inch stainless steel exhaust (That's easy)
