Moton or JRZ?
I think you will find that you get a very similar product from both companies as the founders of each used to work together. I would look at who will provide you better service (setup, valving, rebuild/revalve).
As far as other comparisons, it really depends on your level of suspension needs. For street use, Motons JRZ and similar are overkill in most cases. Even for track days, you can get a very good setup for less than you'll spend on these systems, as long as it's well set up and tuned by a person who knows what they are doing.
If you have the capabilities to out drive the middle level suspensions (KW Club Sports, Ohlins clubs, etc.) then you should look higher, otherwise, you're wasting your money buying capability that you'll never use.
Call Robert Fuller (Robispec) and tell him what you're planning to do, your experience and capabilities. Ask him what he recommends.
Yes. The Motons and JRZ will be substantially more expensive
this is very good advice! you really can not go wrong with ether of your options!
The MOtons have externally adjustable nitogen filled canisters which offer (according to Moton sales) a ton of advantages. I personally have not used them so I can't offer any of those as 1st hand knowledge.
LSD Motorsports
Evo 'For Sale' Services
14
Oct 9, 2019 08:52 AM
