Need help with installed coilovers. Possible problem
Old Apr 13, 2008 | 07:40 PM
Import Junky's Avatar
So I just got done installing my Buddy Club coilovers for my IX. I have roughly a finger width gap between the top of the tires and the fenders. Now I know they're not exact right now but it's too dark and I'm tired so I'll even everything up tomorrow. So onto the possible problem, I decide to get some gas since I needed it and I wanted to test out my new coilovers to check for any problems. So I start off down the road and everything seems fine until I hit a couple of "small" bumps in the road. I could hear some clunking around like metal hitting metal in the back of my car. It kind of sounded like I didn't tighten the nuts on the upper mount inside the trunk. So I check and everything is tight. I check under the car and again everything seems tight. No clearance issues that I can see. I'm running stock tires and wheels. Now mind you everything seems extra loud because I have the rear seats and all of the trunk lining and mats removed from the back of the car so everything is loud. So now I take off down the road again very slowly and start swerving the car hard at "LOW" speed....like a racecar cleaning off it's tires and no noise. Only when I hit little bumps and the car feels good, just doesn't sound good. I left the Spring and damper adjustments where they were out of the box since I'm having everything tuned and aligned on thursday at a local speed shop. So what can it be?
Old Apr 13, 2008 | 07:56 PM
DSMEVOLUTION's Avatar
Welcome to the world of coilovers my friend. My Tein's do the same thing and I have given up on the quest to find the answer. Only my rears make a slight clunk my fronts are quiet as can be. Some coilovers will make this noise while some won't even within the same brands. My car handles like a beast so i have not had any issues.
Old Apr 13, 2008 | 07:58 PM
Thanks for the insight. I just hope it'll be a lot quieter with all of the panels and the back seat installed.
Old Apr 14, 2008 | 05:58 AM
morning bump. any other comments?
Old Apr 14, 2008 | 09:36 AM
Mine does get a little annoying even though it's not a loud clunking. Usually megan racing coilovers have a very loud clunk in which mine is faint but still there. I'm going to try a couple things this weekend, one of which I will remove the top nut and replace with a rubber washer in between the top nut and the pillow ball. I tightened the rear nut as much as I could this past weekend, it moved a bit but was not loose by any means. I also added some grease to the pillow ***** with no luck in reducing the noise. I'm also going to try to run the softest dampening setting to see if that helps. If all else fails I'll eventually order a new pillowball top mount repalcements from Tein and i'll line the strut tower area with dynomat to see if that reduces the noise.
Old Apr 14, 2008 | 10:45 AM
Thanks for the tips. let me know if that rubber washer trick on any other trick works. I'd sure like to atleast dampen the sound.
Old Apr 19, 2008 | 08:19 PM
slvrr's Avatar
I would try a set of heavy duty rear shock mounts.. Or even a set of stock RSM's
