How durable are the stock BBS wheels?
Old Apr 19, 2008 | 06:49 AM
GinNBoost's Avatar
By durable I mean, will they bend easily? I go over some rough roads that are littered with pot holes on my way to work and I can't help but feel bad about the abuse I put my wheels through. Should I be worried that I might dent a rim?
Old Apr 19, 2008 | 09:40 AM
DSMEVOLUTION's Avatar
You have not seen potholes until you've driven in Chicago. I drive daily with my BBS rims and I also have coilovers. I have avoiding and also hit some dccent size potholes without a worry. Don't worry you'll be fine but I would still try to avoid all potholes if you can.
Old Apr 19, 2008 | 09:59 AM
HaVoC RR's Avatar
they are pretty strong!
there forged
Old Apr 19, 2008 | 10:04 AM
BadReputation's Avatar
yeah missouri's potholes are also crazy.. on this one street every year after winter they fix this water line from the pipe exploding for being so cold and they redo the road its bumping as **** theyll nvr fix the problem
Old Apr 19, 2008 | 01:47 PM
Canexican's Avatar
They are Forged...its the most expensive and strongest way to manufacture a wheel. If you bend one of the BBS wheels, you'll bend anything.
Old Apr 19, 2008 | 01:51 PM
Deepseadiver's Avatar
Don't worry about potholes. Pleanty of them here in Guam, and my BBS rims are fine.
Old Apr 19, 2008 | 02:23 PM
High_PSI's Avatar
Stonger and lighter then anything available for the Evo. Just run a 45 series tire on it. I had 19' wheels with 35 series rubber and I bent all 4 in no time. Nothing but OEM wheels for me.
Enkie RPF-1's are great too, get those.
Old Apr 20, 2008 | 02:47 PM
ej20_ftw's Avatar
Tire pressure is the key I guess..
Old Apr 20, 2008 | 03:35 PM
SilvrEvoIX's Avatar
I agree! This past winter was the worst ever in the Chi considering potholes. Winter tires and BBS rims for the FTW during winter!
Old Apr 27, 2008 | 12:32 AM
BoostLover99's Avatar
I've continued to be very impressed with the stock BBS wheels; I've curbed that right rear tire hard enough to push the entire rear end of the car way out (a la power-on oversteer) during a fast right hand turn.
Just a surface scratch but no bending.
They're Terminator strong.
Old Apr 27, 2008 | 06:13 PM
rjdevo9_mr's Avatar
they're very strong
Old Apr 28, 2008 | 01:38 AM
Jeff_Jeske's Avatar
At a lapping day I hit the back side of a corner curb with a 5" lip at about 50mph.
The BBS took the grunt of the blow. I blew an Advan, bent lower control arm, and destroyed a coil over. The rim was damaged beyond repair but did not collapse and stayed round. I was very very impressed with the strength of the rim. I will dig up a picture if I can find one.
Old Apr 28, 2008 | 06:10 AM
OJmobileII's Avatar
Especially after this winter!
Old Apr 28, 2008 | 02:12 PM
turbo271's Avatar
I don't know why you guys are *****ing. I love the potholes in Chicago. They keep me on edge.
AX, here I come
Old May 30, 2008 | 09:05 AM
JuiceUp9MR's Avatar
Boston roads suck!Forged rim FTW!!
