stud busted
Old May 4, 2008 | 04:30 PM
DESERTEAGLE50's Avatar
stud busted
one of studs busted can it be replace ?
Old May 4, 2008 | 05:21 PM
4g63tFan@tic's Avatar
You need to match a stud (thread pitch, diameter and length), then you can just beat the stud out of the camber plate with a hammer and install a new one using washers and a nut to pull the new stud through so that the hat of the stud is flush with the underside of the camber plate. Good Luck
