Argh!
Old May 9, 2008 | 10:11 AM
Eric Keely's Avatar
Argh!
*Update*
Ok, I have a question here, I got my new wheels and installed them the other day. I got the Falken Azenis RT 615, 245/45/17. Everything was fine and stuff, but when I make a right turn, I hear rubbing coming from the front passenger tire. Why? I thought you wouldn't get rubbing until you get to the really wide tires? Can anyone give me insight to this? When I turn left there's nothing... Please help!
Old May 15, 2008 | 06:34 AM
Eric Keely's Avatar
*bump*
Old May 15, 2008 | 01:40 PM
20psiMR's Avatar
245/45 might be too tall. I would have opted for 245/40's to get them closer to stock overall diameter. The stock tires are 235/45, so going 245/45 does make them taller. You might be lowered too much as well, are you stock height, springs or coilovers?
Old May 15, 2008 | 02:02 PM
bchappy's Avatar
does it rub at full lock?
Old May 15, 2008 | 02:49 PM
Eric Keely's Avatar
I don't know why they wanted me at 245/45/17, I would have thought 245/40 would have been better, I don't know. But anyways, I am on stock height. The good thing I guess, is if I wanted to, Discounttire would let me exchange them with 245/40 if I wanted to.
And if full lock means turned the steering wheel all the way to one side, yes, it would rub when I turned it all the way to the right. And it's the front passenger tire.
I am going to check the offsets of the offsets are correct, because I did notice the front passenger tire would stick out more than the driver passenger side tire. Is 28 offset normal?
Old May 15, 2008 | 02:52 PM
EvoBZ's Avatar
I agree.
This is definatly the most likely cause.
Old May 15, 2008 | 02:53 PM
Eric Keely's Avatar
I just played around with the tire calculator, and I think the reason why they went with 245/45 may be because it would affect the overal tire size the least. Changing it to 245/40 seems to have a more dramatic effect.
But one more thing, why only rubbing on one side? Shouldn't it be symmetrical? That is what worries me.
Old May 16, 2008 | 06:50 AM
evo150's Avatar
what size and offset rims are you running? have you gotten a alignment? if so the alignment may be off on the front passanger side.
Old May 16, 2008 | 07:28 AM
TouringBubble's Avatar
Yes, 245/40's are a bit smaller than stock and the 245/45's are closer. I run 245/45s on +35 wheels and have no rubbing issues ... stock or lowered.
Old May 16, 2008 | 07:54 AM
vortico's Avatar
I used to rub slightly at full lock as well with 245/45/17 and also only on the passenger side in full lock. Probably an alignment issue as it was said earlier, I know mine started when I lowered the ride height and after an alignment it stopped.
Old May 16, 2008 | 10:16 AM
Eric Keely's Avatar
Yeah, I think I may just exchange them with the 245/40s...
