Quick ?: Spring Compressor
Old May 27, 2008 | 12:14 PM
Protostar1's Avatar
I have a spring compressor like Autozone's:
http://www.autozone.com/selectedZip,.../selectZip.htm
Do I need 2 of these to compress the springs on my Evo for removal or is one sufficent? Thanks!
Old May 27, 2008 | 12:15 PM
Turbo Kyle's Avatar
Are you doing this with the head on the car?
Old May 27, 2008 | 12:19 PM
4WS Tuning's Avatar
I dont think that tool will fit.... When we did my head we tried everything we could find locally and i ended up having to order this.
http://cgi.ebay.com/ebaymotors/Valve...spagenameZWDVW
Still a pain, but it did its job.
Cheers!
Old May 27, 2008 | 12:27 PM
Protostar1's Avatar
Thanks guys for the quick responses. I am trying to get a hold of a local sears to get one of these, which I believe will do the job:
http://www.sears.com/shc/s/p_10153_12605_00947057000P
Old May 27, 2008 | 01:07 PM
DaWorstPlaya's Avatar
Cheers!
The OP is talking about suspension springs not valve springs. Yes the one listed in the 1st post should work fine ...
Old May 27, 2008 | 01:12 PM
djh's Avatar
djh
That'll do it for you, but any tool meant for MacPherson struts will work. The first one is meant for springs that don't have the damper running through them. Just do a reasonable job getting the clamps across the diameter of the spring and compress them evenly. As long as the spring isn't noticeably bowed you're OK, there's not a lot of preload in the stock springs anyway, and even less in most aftermarket springs. You may not even need the compressor when you put things back together.
And guys, he's talking about suspension springs, not valve springs!
Dave
Old May 28, 2008 | 09:36 PM
barneyb's Avatar
I have the spring compressor pictured in the first post. I used to own two Trans Ams, a '78 and a '79 and I used this tool to change front springs on them. They did not have McPherson Strut suspensions. The next tool pictured is what you need and yes you do need two.
