Rear wheel stud replacement
Old May 30, 2008 | 12:59 PM
tseitz123's Avatar
Question Rear wheel stud replacement
Hi all. I just picked up a set of ARP extended wheel studs and managed to get the fronts installed fine, but the rears are proving to be a big PITA. Damn e-brake assembly. Anyway, I searched the How-To section and was able to find help with the fronts, but the rears... Any tips or advice here? I'm assuming I need to take off the whole wheel hub, but idk.
Old May 30, 2008 | 02:47 PM
DaWorstPlaya's Avatar
From what I have read, the proper way is to take off the hub and press out the studs. Then install the new studs and tighten/set them using a nut.
Old May 30, 2008 | 03:28 PM
leecho's Avatar
I was able to do one without taking off the hub. The stud came out pretty easily just tapping with a hammer once I got the rotor off. Getting the rotor off was the hard part.
To get the rotors off, there are two threaded holes in the rotor - at least on mine a bolt nearby holding a retaining clip for the brake line was the correct size to go in there.
Anyways, thread the bolt through those holes and it will get the rotor free. Like I said, I don't know about all 5 or extended studs - but I was able to remove and replace just one without pulling the hub off.
poonpower
Oct 22, 2016 06:35 PM
Prime12
Nov 6, 2015 11:59 PM
_Evoke_
Dec 4, 2014 05:15 AM
bradze
Aug 31, 2010 09:29 PM
p.phresh
Jul 22, 2009 11:34 AM
