Wheel and Tire Size for Autox/Track/Spirited Driving
Whats the black thing you used as the lip?
How did you cut the radius of the fender? Just eye ball it or marked it with a marker?
What did you use to cut it, dremel?
The lip is nothing but the door edge rubber protectors they sell at your regular autoparts and I just cut them to the desired length.
I had made fender flares but decided not to go with them because the cut fenders don't look too bad and the street tires look ridiculous under the flares.
To cut the fenders, I marked them with a pencil and used an air metal shearer that went trough the front aluminum fenders clean and straight.
The rear quater panels were a little harder as there is an inner steel reinforcement that needs to be cut with a rotary wheel cutter. The whole process took me 2 hours with the right tools and was well worth it because I can run 335 front/ 315 rear on 17" wheels.
the concern on rubbing is a matter of offset and tire choice. The width of the wheel is going to cause the tire to either bulge or be stretched, so they really play little impact on wether or not it's going to rub because most rubbing is cuased by the outer shoulder of the tire (edge of the tread) not the side wall.
I run 17x10 +23F +33R (I got a deal on a used set otherwise I might have got the 9.5") with 255/40/17's lowered on swift springs and I don't even have my fenders rolled so you definatly could get away with a bigger tire.
Now I am glad I have the 10" width because my next set of tires will be 275's so I feel it is a good route. But 9.5 or 10 I think you will be happy and get a lot of grip.
If you want a street/autocross tire, don't underestimate or forget the value of some really good 245/40/17s. There's a reason STU class makes sense for Evos
If you want to do more high speed HPDEs on track, 255/40/17s like RA1s or some of the other light race tires would be a good start. If you get some 17x9s you could run either of these tires to good potential.
That's a good starting point, especially before you have serious suspension, and also after.
krzys4
10
Jun 14, 2012 07:36 PM
westmc
17
Apr 5, 2010 07:26 AM
evoguam
Oct 2, 2006 04:09 AM
