please help
Old Aug 9, 2008 | 06:46 PM
gdup's Avatar
please help
i just installed springs installed and now when i turn right i hear a cracking noise. It is kind of clicking but not repetitively so might not be axle. It sounds like two clikcing noises repeated. It only happens when i turn right and is gettin pretty loud. Tomorow i will take the wheel off and check but what do you guys think? i really need some help.
Old Aug 9, 2008 | 06:48 PM
vaboostn33's Avatar
spring may not be tightened down completely.
Old Aug 9, 2008 | 06:55 PM
gdup's Avatar
gotta check
i am kind of pissed and tired of things not working out. i will just have to wait. thanks . i will def chek that.
Old Aug 9, 2008 | 07:07 PM
JakeTheVIII's Avatar
I had the same thing when I first installed my Tanabe GF210's. I never figured out what it was, but it went away after a few hundred miles. Maybe they just need to settle while you drive around for a while.
Old Aug 9, 2008 | 07:14 PM
gdup's Avatar
geting louder
i heard it before but now that i lowered the music and put the car in neutral i can hear it and it is pretty loud. THey were saying the strut housing that holds the spring was damaged. could that be it and what exact part would that be?
Old Aug 9, 2008 | 07:24 PM
I don't know, but probably much like the 2 pieces at the top of this pic. Theres a ring where they fit in. I doubt that's damaged though unless you really screwed up installing them.
Or like the fatter parts where it holds the spring on the 2 struts on the right. Hope this helps.
Edit: I have the pictured parts for sale though, if you think you damaged anything...
