my brakes sqweek really bad after dusting them and everything and they have alot of life left and sometimes well most of the time the right front tire will squeek when i drive and it gets annoying cuz im not using the brake and u hear squeeking its not bad but it gets hella annoying does anyone have the same problem
thanks ...
thanks ...
try some brake quiet. Take your pads off and spray this stuff on the back of the pad. you can find it at your local auto parts store. Try greasing the brake pins as wells with brake grease. If that doesnt work then its time for some new rotors.
evo brakes will make some noises some times. that's the nature of the beast.
are you on OE pads? sometimes my brakes will squeal when they have been sitting, or are very hot from being used. also, many of the aftermarket pads for our cars are much more noisy than stock.
unless you're on OE pads, and it is constantly making noise, i wouldn't worry about it too much. the evo makes many noises because it is kind of a high strung car.
As everyone else has asked, which brake pads are you currently running?
im not sure i just got the car not to long ago but the pads are good im going to try to grease them with break grease and spray the pads ill let you kno thanks
wait he said its squeeking while hes not on the brake. mayb the backing plate is slightly touchin the bac of the rotor. i see that all the time at work. alot of times thats the squeeking they hear when they are nhot on their brakes. or your pads could just be completly gone
