p45r fitment.please help
Old Oct 15, 2008 | 09:42 AM
pjb00stin's Avatar
hey guys,
my buddy's selling his rota p45r's in 18x9.5 +35 offset.will these fit an evo?will i have to run spacers/roll fenders?i have an VIII with tanabe gf210's.thanks!!
pj
Old Oct 15, 2008 | 09:45 AM
pjb00stin's Avatar
also, the tire size is 255/35/18
Old Oct 15, 2008 | 10:03 AM
goofygrin's Avatar
ur gonna rub rub rub all the live long day on those.
Old Oct 15, 2008 | 10:46 AM
pjb00stin's Avatar
oh noez!!
Old Oct 15, 2008 | 10:57 AM
goofygrin's Avatar
Check this:
https://www.evolutionm.net/forums/sh...d.php?t=375308
The ones you are talking about will give you 1mm less room outside and 11mm less room inside.
What's the stock wheel spec?
Old Oct 15, 2008 | 11:06 AM
goofygrin's Avatar
You should contact wheeldude.com since he'll be able to tell you for sure what you'd need to do. It looks like you'd need like a 10mm spacer or something!
Old Oct 15, 2008 | 11:49 AM
WheelDude.com's Avatar
I replied to your PM about the wheels. For anyone else curious, 18x9.5 +35 P45R wheel will not clear Evo calipers in front. The recommended setup is 18x9.5 +30 all around and then you would use a small spacer in front for caliper clearance. A 5mm spacer with the 18x9.5 +30 will allow these wheels to just clear the calipers and you can still use stock wheel studs.
If you get the 18x9.5 +35 wheels you will need a large spacer up front. Ideally you would want to run a 10mm spacer which will require extended wheel studs in front. Some 255/35/18 tires run wider than others so it's hard to determine the exact alignment you will need, you will need more camber than your current -1.3 front unless you roll your fenders.
-Dan
Old Oct 15, 2008 | 12:41 PM
def1's Avatar
im on rota p45r 18X9.5 +35. I have wider front fenders and rolled rear fenders tho. But no rub.
Old Oct 15, 2008 | 12:44 PM
goofygrin's Avatar
What's your suspension though?
Old Oct 15, 2008 | 06:40 PM
def1's Avatar
stock. but i had the tein s tehcs befroe and they would only rub if people sat in the back and let me tell you those springs are low!
