vibration when braking
Old Oct 17, 2008 | 02:41 PM
Evo9"Miss Rose"'s Avatar
shi* my rotors are at minimum at 35k mark im at 42k now i think its time to change my ROTORS aswell +1 my wheel shakes like no other when i hit the brakes
Old Oct 18, 2008 | 05:20 AM
slvrr's Avatar
Most cases its an alignment problem or wheel out of ballance. Other than that I would say brake pad build up. Dics's don't warp perioid thats a misconception. Rotorpro's would be the way to go for sure. Be sure to change your pads and brake fluid when you do your rotors, hell you might as well add SS brake lines while your at it haha
Old Oct 18, 2008 | 06:32 AM
garcias2k's Avatar
I'd say that its the warped rotors. My stockers were bad so I had them turned. Few months later they were warped again. So I switched to the brembo cross drilled on all fours, no more problems.
Old Oct 18, 2008 | 06:45 AM
emilebazin's Avatar
You might need wheel alignment
Old Oct 21, 2008 | 07:43 AM
mykrofon's Avatar
i doubt its wheel alignment...i mean its only when braking....other than that it doesnt shake at all...plus i feel the break pedal shake as well
Old Oct 21, 2008 | 08:05 AM
chu's Avatar
chu
Originally Posted by Knightr
PF 2 Piece Dimped best rotors out there... also when the rotor gets worn down just buy new rotors saving cost... reuse the HATs...
if you want to cool those brakes the only REAL way is AMS brake cooling kit have it installed and never over heat now...
check here for the VR guys who installed mine.
http://www.vrperformance.com/mt/2008...rade.html#more
This is overkill for a street evo. You dont need all that, and a pair of replacement rotors from PF are about $400, so cheap by no means given you still have to do the work in putting the hats back on. The OP needs new rotors, and pads, and change the oil while you're at it. When putting the wheels back on, make sure they are torqued equally all around.
Old Oct 22, 2008 | 07:29 AM
mykrofon's Avatar
thanks for the chime in guys
