I am wondering how much weight can you save by filling the tires with nitrogen instead of air? Can any tire be fill with nitrogen?
thanks
thanks
Quote:
don't waste 20 bucks Originally Posted by S2kracka
Any tire can be filled with nitrogen but don't waste your time or money.
, if the GTR tires are fill with nitrogen it has to be for a reasonEvolving Member
The answer is yes. But why waste your money on that. I would perfur to put my money else where.
I'm no expert, but I heard somewhere that the advantage of nitrogen in tires is not weight savings, but instead more consistent tire pressures in varied temperature conditions (like racing). The tire shop I use to have tires mounted uses nitrogen (no extra charge), and I've noticed that I rarely have to add air despite seasonal changes.
RedAustinIX
RedAustinIX
Quote:
he said nitrogen, not helium Originally Posted by sharkm87
your car will float away
And if you're concerned with losing weight...the air in your tires is your least concern.
Quote:
RedAustinIX
Precisely.Originally Posted by RedAustinIX
I'm no expert, but I heard somewhere that the advantage of nitrogen in tires is not weight savings, but instead more consistent tire pressures in varied temperature conditions (like racing). The tire shop I use to have tires mounted uses nitrogen (no extra charge), and I've noticed that I rarely have to add air despite seasonal changes.RedAustinIX
My jeep's tires are filled with CO2 from the tank in the cargo area. Nice being able to air down and up without hitting up a gas station, plus it takes about 45 seconds to fill each one form 14-30 psi.
Nitrogen gives you a more consistent tire pressure for daily driving and track. With that in mind, gas milage can be affected. My wife has a 2008 Sante fe. After putting nitrogen in her tires the car felt a little more steady on turns and the MPG tracker increased about 2 mpg. Oh, in case you have that bad oops real bad, NASCAR implemented nitrogen for the fact that its non-flammable. Regular air will fuel a fire. Nitrogen won't. Just food for thought.
Air is about 78% Nitrogen already. Give me a minute and I'll try to post a SCC article on the Nitrogen debate.
i have no response for thatOriginally Posted by QwikSRT4
Quote:
RedAustinIX
This is exactly rightOriginally Posted by RedAustinIX
