Bilstein compression question
I just got my used MR Bilsteins installed and when I was swapping the stock shocks I noticed the stock shocks seemed stiffer. I pushed the rod end down on both and the stock ones seemed stiffer on all 4. Is this normal or did I get blown shocks? They seem to ride good w/ no bouncing.
Highly unlikely they are blown.. Usually a few good pumps is needed to build pressure after the shocks have been sitting on their side during shipping, storage etc.. Mike is rt, they are softer but you would feel that iafter the install, not on the ground or by hand.. I have them, they are great.
It has to do with compliance....with our bumpy US roads, having a shock that is slightly softer, or better subscribed as complaint, does a better job of keep our tires on the road giving us grip rather than having them up in the air because the suspension couldn't soak up the bumps.
I was under the impression that the Bilstein/swift set up was superior to the KYB/swifts, is this not true? I might swap back to KYB's unless someone convinces me otherwise.
Yeah, they just feel "sloppy", I've had lowered cars w/ aftermarket shocks and they have always had a stiffer feel. I was just expecting a more precise, controlled feeling. I've only had them on for 2 days so maybe I'm jumping the gun.
How was the car aligned after the install?
It is a very different feel from the KYB's, but "sloppy" concerns me. Do transitions/slaloms feel especially bad?
- Andrew
