Allignment Advice
Old Dec 10, 2008 | 08:59 AM
SilverBulletIX's Avatar
Allignment Advice
Ok so I just installed Swift Sports on my stock MR bilsteins as well as F & R whiteline sway bars and need an allignment. I am currenlty running Toyo Prox 4's on the stock rims and the car is mostly used for pleasure(garage kept) but not tracked. I know... I have used the search button b/c I know a lot of you will say that I will find my answer there but the answer I found was it all depends on what your setup is...
Thank you in advance for you advice.
Old Dec 10, 2008 | 11:17 AM
Smike's Avatar
Does not depend on setup. This has been covered.
Use the -1 bolt selection up front (you will have a true alignment of -1.5 to -1.7) and get aligned for -1 in the rear. Zero toe all around.
Old Dec 10, 2008 | 12:16 PM
Thank you sir. You were also a big help when it came to selecting my Swift springs
Old Dec 10, 2008 | 03:53 PM
Smike's Avatar
