the official VOLK TE37 thread...
Old Jul 13, 2018, 04:52 PM
  #811
Received 1,384 Likes on 1,317 Posts
Originally Posted by Evo Inertia
Well **** I wish the guys at vivid racing would have said something about that. I wouldn’t have bought these things knowing body work needs to be done. What would you suggest? Smaller tire? Smaller wheel? If so what’s the biggest te37 I can run without modifying my fenders? Maybe a different offset in the rear...
What you bought is a very popular size & offset designed for the Stance fit. None of the road coarse / function guys run that offset. Most function setups are running +30 to +38 & even at that we needed some rear fender work
Heck, i was fitted for the following spec: 17x9.5" +30 w/a 275/40 tire. My EvO rears needed everything your +22's will need w/a modest 255/35 tire.
If youre more Stance oriented, then a super tight rear fender roll w/some heavy negative camber & ride height may get you by (would not work well at the track or aggressive driving )
Evo Inertia (Jul 14, 2018)
Old Jul 13, 2018, 05:39 PM
  #812
Evo Inertia's Avatar
What you bought is a very popular size & offset designed for the Stance fit. Non of the road coarse / function guys run that offset. Most function setups are running +30 to +38 & even at that we needed some rear fender work
Its definitely not going to the track. It’s a daily driver that I’m not too hard on. I also forgot to mention it lowered .9 inches in the rear. Also I’ve been looking around town and no one will roll fenders. They say it’s a liability. Unless I want to buy a fender roller and do it myself I’m screwed. I’ve never rolled a fender before so I’d be a little reluctant to try myself. Sigh. Thanks for your help. No clue what I’m gonna do now
MinusPrevious (Jul 14, 2018)
Old Jul 13, 2018, 11:28 PM
  #813
OneSlowEvo8's Avatar
im in the same boat as you man. I have a slight roll on rear fenders but that is it. I talked to a guy local to me, he has a Beatifully EB 9 on 18x9.5+22 on a 245/40/17. Fitment is pretty nice. He’s pretty damn close for fender to wheel gap. He said he slightly rubs depending on bumps and passengers. I will end up going with the exact set up he has and just keep about a fingers gap for clearance and have coilovers pretty stiff. Might end up getting an alignment and getting some very slightly camber. If it rubs a tad tad bit I’m fine with that. I recommend at 245 tire tho.
  #814
correction 245/40/18***
Old Jul 14, 2018, 05:01 AM
  #815
Per your PM request, heres a pic of the bumper bolt relocation done on my set-up
The following 2 users liked this post by MinusPrevious:
Evo Inertia (Jul 14, 2018), labshazam (Aug 27, 2023)
Old Jul 14, 2018, 01:53 PM
  #816
So I just bought a fender roller. Going to give it my best to make these bad boys work. Gonna go slow and take my time to do it right. One more question, sorry man. Will I need to remove the wheel well liner and if so will it fit back into place once the roll is complete?
MinusPrevious (Jul 15, 2018)
Old Jul 14, 2018, 02:04 PM
  #817
Yeah, for sure take your time & go over the how-to Vids on YT. Youll want to use a heat gun, on the paint, so it doesnt crack. There is no rear fender liner (only the fronts have those)
Old Jul 16, 2018, 08:50 AM
  #818
Abdul Wahab's Avatar
Originally Posted by H8WRX
17x9 +15 on 235 45 17
did u need to roll the fenders for this fitment??
Old Jul 16, 2018, 08:56 AM
  #819
did u need to roll the fenders for this fitment ?
Old Jul 16, 2018, 04:27 PM
  #820
Astro_Train's Avatar
yes, any 9 inch rim with an offset lower than +28ish will require fender rolling. That tire is thin for a 9 inch rim but will "help" with fitment.
Old Jul 17, 2018, 07:19 PM
  #821
Anyone have a link for how to adjust your camber on an 8?
Old Jul 17, 2018, 07:34 PM
  #822
You really need to have the cambers & toes set by a shop. Here are the snippets from the manual on the front & rear. Its good to be aware of the front camber bolt & in which direction its placed to achieve the -2 degrees if needed
Old Jul 22, 2018, 07:13 PM
  #823
Success! Managed to fit the te37s 18x9.5 +22s with just a tight fender roll! Zero rub. Very happy with the result👍
MinusPrevious (Jul 23, 2018)
Old Jul 22, 2018, 07:27 PM
  #824
Ooooh. I like that look. Very clean. More shots needed
Well done
Evo Inertia (Jul 22, 2018)
Old Jul 23, 2018, 03:00 PM
  #825
tire specs?
Quick Reply: the official VOLK TE37 thread...
