The Brake Rotor, Pad, Line, Fluid, and Duct Thread
#181
Ok.. I'm reporting back:
8 track days under my belt now, and a total of 5 of them are on these Rotorpros slotted:
What do you guys think? There are obvious hot spots on one rotor, and on the other (more evident on one than the other) there are some miniature splits on the surface. Time to replace? There is no warping, and the car still stops like i'm dropping out a boat anchor
I am on 245/45/17 R6's, Raybestos ST-43's front/back, and forge motorsports ducts.
Thanks!
Thanks!
#183
Thanks!
Thanks!
You don't want to see what the OEM rotors I used for about 10 track days look like.
#191
What is "cheapie" $$ amount for rotorpros? My idea of "cheapie" was a Winhere brand, going to see how it fares probably soon since my stock OEMs are showing runout after 37000 miles plus 5 hard track days. $113 shipped for front rotor pair/set was too low to pass up, just to try them out.
#193
Are there any Ti heat shields out there for the X's rear pad shape? Is there any need for them? I plan on heating up stuff more now with racing pads, so I want to do the obvious and easy things to manage that condition.
#195
I've thought this over more, being a pretty solid Mech Engr (education, not current), that the steady state temp will be reached pretty fast with anything that's not a brick. Net, while they might provide a temporary amount of time delay, once up to temp, any shims won't do diddly.
The SS lines I have ready to put on, them's another tale! Also glad I have the air guides. While not ducts, it's better than stock. I think I'm equipped now as is to up the anty in heat and hope my red returns afterwards!
