The Brake Rotor, Pad, Line, Fluid, and Duct Thread
Old Dec 30, 2008, 12:45 PM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
The 2005 has an ACD unit.
Old Dec 30, 2008, 12:51 PM
Kracka's Avatar
What are your thoughts of SS brake lines for a daily-driver/autocross Evo? I've read everything ranging from "OMG these helped so much!" (which I chalk up to the fact they now have new fluid) to "they don't do much, especially for a street car" to "they'll potentially cause more problems than they're worth." The last one is particularly intriguing to me since a local Evo guy did have one of his SS lines crack after only a year or so of use. The company sent a replacement free of charge, but still quite a hassle.
Old Dec 30, 2008, 01:02 PM
adamweldonjohns's Avatar
Stickie this thing! If the "official modding for dummies" got stickied, this certainly should.
Great, concise write up!
Old Dec 30, 2008, 01:17 PM
chu
chu's Avatar
On the SS lines, you want to start with something that has DOT approval, as mentioned in the thread. I would recommend something that has a coating on the outside, which serves to protect the stainless lines from rust and so on. I'm using the techna-fits, and they are dot approved and has that protective coating.
Old Dec 30, 2008, 01:43 PM
Kracka's Avatar
Unfortunately, the lines that failed were TechaFits. The new line supposedly looks much nicer though so hopefully it'll hold up better.
Old Dec 30, 2008, 01:59 PM
Bster13's Avatar
perhaps it was a new revision from TechaFit?
Old Dec 30, 2008, 02:46 PM
Smike's Avatar
Pure daily driver or occasional AX - OE lines.
Been on the Technafits for a while.
Old Dec 30, 2008, 04:33 PM
SWOLN's Avatar
My guess is you haven't found any that work with the 2005 either, if you have please post that information. Thanks for you valued input.
Old Dec 30, 2008, 04:39 PM
Smike's Avatar
I have seen a bunch install a BDCK on their IX's
Where the IX has the IC holes in the bump. Many are using that area to up the ducting - pretty much how I had mine.
https://www.evolutionm.net/forums/mo...tallation.html
Mine right now are behind the lip. I will remount them this spring.
Old Dec 30, 2008, 09:25 PM
SWOLN's Avatar
I remember reading that a while back. Unfortunately, my holes are blocked by my IC. ... and i dont want it to look dodo. ...but if it works I suppose track day installs could be considered. Do you think thats enough air through those smallish hoses for road racing, as opposed to parking lot warrior?
Old Dec 30, 2008, 09:43 PM
Smike's Avatar
Function > Form in most cases for my book. Ducts help - run them if you got'em
Old Dec 31, 2008, 07:34 AM
Bster13's Avatar
Taken from this website:
http://www.wolfkatz.com/products.php?cat=25
- Porterfield R4S Pads are a great choice for spirited driving, autocross use, and light track use. They are a low noise and low dust perfromance pad with excellent wear characteristics.
- Raybestos ST43 Pads are a great track pad with extremely high temperature ratings (1400 degrees F), high friction coefficient, and excellent wear. These pads can be used on the street, but will make more noise and more dust then the R4S pads.
Take it for what it's worth on the ST43 temperature ratings!
Old Dec 31, 2008, 10:55 AM
Smike's Avatar
Thanks updated!
Old Dec 31, 2008, 11:27 AM
OldschoolEVO's Avatar
Awesome post!! I'm kinda obsessed with brakes.
Would probably help to include the different ways of bleeding the brakes. I personally use/love the Motive power bleeder
Old Dec 31, 2008, 12:46 PM
AlwaysinBoost's Avatar
great post smikey.
I recently purchased Kyle's BCDK.
Quick Reply: The Brake Rotor, Pad, Line, Fluid, and Duct Thread
