GTWorx with MR. Bil
Timujin, how do you have your front stock camber bolts setup? At the -2 position (facing outward), or the -1 position (facing inward)..
Got my car aligned and with the -2 position, it's at
Front Driver Side = -1.8
Front Passenger Side = -1.6
I'm thinking this might be a bit much for the streets and will give me more tire wear than normal. Anybody here set their camber bolts to -1 w/ the MR bilsteins + GTWORX springs? If so, what are your camber settings after alignment?
As long as you're running 0 toe, -1.8 is not going to be bad at all.
But if you do long extended periods of highway driving, the -1 setting might work better for you.
- Andrew
- Andrew
Camber bolts are set at max camber, I forget if the arrows point in or out. Tire wear hasn't been too bad, but I don't daily drive my EVO. I need to get an alignment refresh because the car is a little darty over road imperfections. I am running RE01Rs and I may switch to less agressive front camber to preserve them.
GTWORX.com
109
Oct 24, 2022 03:42 PM
TouringBubble
62
Aug 7, 2012 09:57 PM
GTWORX.com
Feb 18, 2009 09:30 AM
Zeus
Nov 2, 2008 01:27 PM
Zeus
Jan 10, 2008 04:19 PM
