anyone ever use a vacuum/pressure bleeder?
Has anyone ever use a vacuum/pressure brake fluid bleeder?
Curious if a vacuum bleeder such as is available from Griot's Garage, which sucks the old brake fluid out from the bleeder valves
versus
a pressure bleeder such as is sold from Bavarian Autosport which forces new fluid from its own reservior into the reservior on the master cylinder, forcing the old fluid out the bleeders.
They both cost in the range of 70-ish dollars.
Any experience with either type? Which is better/easier to use/does a better job?
I live in the middle of nowhere and have to do it by myself so the pedal pump method w/ two people will not happen.
versus
I've used both and currently have one of the Griots suction devices. Both work very well and each has their own peculiar problems.
The biggest problem with the Griots unit is the suction can be too much at times and it will suck air from between the threads of the bleed screw and the caliper body. A dab of grease and some teflon tape on the threads helps. Also make sure the rubber/plastic fitting that goes over the nipple on the bleed screw seals or you'll see bubbles in the tube (not coming from the braking system though). The Griots thing comes with a MC filler device that works for most MC reservoirs.
The pressure bleeders must properly fit your MC reservoir filler so several adapters may be required to work with different vehicles. The pressure bleeders, depending on which one you get, hold more fluid so there is more waste.
If you're changing fluid, plan on pumping/sucking a least a pint per corner past clear (or the new color). So you'll need lots of fluid.
Very helpful response. Thank you.
If you had to spend your own money again, which would it be? Ever use the Motiv pressure bleeder? Aso wondering what you mean by "depending on which you get" wastes more fluid. Are you talking about the size of the reservior?
Also, did you have to repeatedly stop the suction on the Griot's device to refill the MC fill device?
I used both as well. Started with the vacuum type, Mityvac, cuz I could buy it locally for cheap. It sucked, yet couldn't really suck, haha. It took like 15minutes of pumping the vacuum per brake nipple--what a hand workout. I ended up buying Motive's Power Bleeder and that worked wonders...less than a minute per nipple and you didn't have to worry about making sure the brake fluid reservoir had enough fluid in it. I should have bought the Power Bleeder to begin with.
If you follow the rule that any fresh brake fluid that has left the original can should never be reused, then whatever amount of fluid you fill a pressure bleeder with must all be used up or tossed. So there can be more waste. That's what I'm referring to.
I have not used a Motive pressure bleeder. A MitiVac would be just painful I'm sure.
I change fluid in each of my cars yearly and immediately before doing any brake caliper work.
Thanks again for the great responses. seems like it comes down to whether you prefer forcing it through from the MC or sucking it out from the bleeders.
Ever have the Griot's "thingie" :] tip over on you? They relly do make nice stuff.
Also, while we are sort of on the subject, How have you guys dealt with the ABS system? I've seen suggestions on the forum ranging from "the car has to be running while yu are bleeding the brakes" to "bleed everything, go drive the car, make the ABS kick in, go back to your garage and bleed everything again"
Thanks again, guys
Tom
Thanks again, guys
Tom
Perhaps a more important question is how do we make sure all the "old" fluid inside the ABS valves and tubing gets changed?
No, haven't. Even if it did, nothing would leak out cause the whole liquid container portion is sealed, and probably under vacuum. When you're done sucking, bleed the vacuum out (has a bleed valve) then pull out the tube connector (seals with an o-ring) and pour the collected fluids out and rinse out the container. Just like pie.
I wonder about the lines for the ABS as well. If you were to do the "Drive around" method, and bleed everything again, I wonder if you would even be able to tell the fluid from the ABS system and if it would even look dirty because of it being diluted ffom all the fresh fluid you put into the system on the first flush....
I think the one I have is the Motiv, use the Ford 3 prong (I think, screws right into the mc) mc connector and not the tuner one (generic clamp, people have had problems getting a good seal). If you call their office and tell them it is an Evo viii/ix they will know which Ford one to use. Fit was perfect, easy to use, no complaints at all. They are a couple cities down from me, and the guy who runs their office dropped mine off on the way home from work the same day, so their customer support I would give a big thumbs up as well.
I was thinking of buying the vacuum style that utilizes an air compressor line to create the vacuum (save your hands!) and use a small regulator to control the suction. The problem(s) I've had with the hand suction styles is the hose to bleeder and hose to hose connections not sealing enough to hold vacuum. Thoughts? Clicked & subscribed.
