Whiteline W0588... where does this go?
Old Feb 9, 2009 | 04:37 AM
KevOVIII's Avatar
https://www.whiteline.com.au/store/d...asp?part=W0588
Whiteline calls it "Bush kit-toe control arm inner"
Speed Element shows that installation should be here
In this thread griceiv mentions that the kit is the same as Whiteline's KCA388 (rear bump steer kit), but it doesn't have the offset hole:
https://www.evolutionm.net/forums/br...-question.html
This thread says that the inner and outer are sperical bearings and that the only bushing for the lower arm assembly is the one that connects to the shock:
https://www.evolutionm.net/forums/ev...-bushings.html
So my question is, has anyone installed W0588? If so, where does it go? It definitely doesn't replace the LARGER inner bushing... unless you to press out the spherical bearing while keeping the rubber/metal sleeve in there, then press in the W0588 bushing within the sleeve.
I tried pressing out the spherical bearing, but stopped when things looked weird.
Old Feb 10, 2009 | 01:03 AM
KevOVIII's Avatar
Anyone installed these?
Old Feb 10, 2009 | 01:25 AM
smack_evo's Avatar
yeah that inner is spherical so i can't see why you would swap that out for a urethane bushing if it's not to run the bump steer deal. otherwise no point
Old Feb 10, 2009 | 01:51 AM
KevOVIII's Avatar
I assume you're Sean, right? I recognize that picture from EE.
Thanks for your input. Any idea why those bushings were made? If the spherical bearing/bushing is pressed out, there's no way the tiny W0588 would fit. Unless it's the inner bearing (the spherical itself) is pressed out, leaving the sleave (or whatever it's called), then the Whiteline bushing pressed in.
Old Feb 11, 2009 | 11:33 AM
KevOVIII's Avatar
Anyone?
Old Feb 11, 2009 | 07:52 PM
Yogi_B's Avatar
I don't know what speed element are on about because the pic they have is the lower arm, that bush kit is for the toe control arm which replaces these bushes.
Old Feb 12, 2009 | 03:25 AM
KevOVIII's Avatar
So this kit is the same as the bumpsteer kit (KCA388) minus the bumpsteer correction feature?
Tmosser
Apr 22, 2016 12:01 PM
OverBoostedEvo
Apr 9, 2015 01:14 PM
miragevo
Nov 15, 2010 12:06 PM
EvoIXMR
Jan 22, 2008 10:03 AM
20psiMR
15
Nov 20, 2007 01:10 PM
