Coilover Opinion
Old Feb 17, 2009 | 05:03 PM
GTWORX.com's Avatar
Sure did. You know who got it right?
These guys:
- Andrew
Old Feb 17, 2009 | 05:06 PM
18bora's Avatar
What about 12k front, 10K back+ RSB?
Old Feb 17, 2009 | 05:09 PM
GTWORX.com's Avatar
To the OP, I haven't tried them but i do hear pretty good things about Stance. And i think you can get custom rates.
- andrew
Old Feb 17, 2009 | 05:11 PM
GTWORX.com's Avatar
Better, but more than just the getting the balance of the car right is optimizing how it reacts to bumps in terms of the front and than the rear. I'll start a new thread since I've thread jacked this one enough. Sorry tonba.
- Andrew
Tonba's Avatar
^ Thats good, because im considering buying them..
So HKS didnt get it right with the Hypermax Evo?
Old Feb 17, 2009 | 05:24 PM
GTWORX.com's Avatar
In my opinion no they did not at least in terms of spring rates. I really like KW's for example but their spring rates are bad too. But they have great valving, so we do custom spring rates with them and it works well. HKS with custom springs might be alright too. I don't know if they offer it or if they use normal spring sizes so you can swap them.
- Andrew
Old Feb 17, 2009 | 05:30 PM
Tonba's Avatar
^ Yet the HKS evo is still concidered the quickest circuit car/ time attack car in the world..?
Also, isnt it the swaybars job to controll bodyroll & understeer + oversteer..
The springs are supposed to help the shocks in controlling the wheels/tires.. ie, keeping them on the ground..
So if im running my cusco front sway and an agency power rear with endlinks, then I throw the stance coilovers on at 9k F and 8k R it would handle like crap?
Old Feb 17, 2009 | 05:34 PM
Tonba's Avatar
Ok, moving away from the spring rate arguments.. *lol*
You believe the stance coilovers AL+ Pro have good valving? Do you believe they are a quality item?
Old Feb 17, 2009 | 05:40 PM
GTWORX.com's Avatar
If they use stiffer front rates on their race car, I will be very surprised!
I've heard good things, but that should always be taken with a grain of salt. Haven't had a chance to ride on them or look at any data on them.
- andrew
Old Feb 17, 2009 | 05:54 PM
Tonba's Avatar
Do you know where I could find some data? Or people that are running them that I could ask?
Old Feb 18, 2009 | 07:38 PM
bluemonster2's Avatar
r1 coilovers are amazing. good bang for your buck.
Old Feb 19, 2009 | 07:36 AM
donour's Avatar
In Japan, and here is Australia.. Stiffer springs in the rear seems silly, as a majority of the weight is over the front wheels.. Makes the car too taily..
This is a good point, but you're asking the wrong question which is probably why GTWORX's explanation doesn't make much sense.
When thinking about the weight distribution, you want to talk about wheelrates, not spring rates. The wheelrate is the springrate multiplied by the lever arm that it is attached to. It is the springrate _at_ the wheel and the only thing you should use to compare front in rear. You DO want higher wheelrates in the front because it is heavier.
However, the front and rear Evo geometry is different. You can have higher springrates in rear, but still have lower wheelrates. This is different from, for example, the old Subarus which have struts all around. They have basically the same lever arm factor front and rear so you want to run rates that basically mirror the weight distribution.
This is why so many fast people slightly higher springs in the back and why the car comes from the factory with higher rear rates. I really believe that a lot of coilover manufacturers are just lazy and and basically just copy their setup from another application (such as the subaru or honda) and don't really sit down and think about the evo as a different platform. They try them out and say "wow, this is better that stock" without realizing there is more on the table.
Hope this helps.
d
Hiboost
75
Dec 4, 2019 05:09 PM
GTWORX.com
402
Dec 17, 2018 10:31 AM
LCS
42
Jun 17, 2016 12:01 AM
Hiboost
10
Jan 20, 2010 05:56 PM
500whp.com
Jun 5, 2006 11:10 AM
