Tire Pressure ??
Old Mar 13, 2009 | 04:42 PM
cij911's Avatar
Tire Pressure ??
Hey I am running a 17x9.5 Enkei NT03 with a Falken Azenis 275/40 (street tire ). Any recommendation on cold tire pressure settings? (The factory tire pressure recommendation is 32F/29R.) Thanks
Old Mar 13, 2009 | 05:05 PM
Smike's Avatar
34 f and 36 r is where I like to start with my tires/susp combo. I go up or down depending on IR gun readings and feel.
Old Mar 13, 2009 | 05:30 PM
cij911's Avatar
Thanks Smike ...Tire temp. readings on a street tire (?)...I have an IR reader and a tire pyrometer, but thought that was only applicable on race tires. Are you looking at just the temperature gradient (looking for a linear distribution from inside to outer edge)?
Old Mar 13, 2009 | 06:07 PM
Smike's Avatar
Correct. I tracked the last few seasons on street tires. So the idea still works.
Old Mar 22, 2009 | 07:54 AM
cij911's Avatar
Anymore tire pressure suggestions from people running the Azenis 275/40 /17 ?
Old Mar 23, 2009 | 09:40 AM
sblvro's Avatar
I have the stock advans A046, does the 36psi on all fours apply or do I have to do 45PSI front and 35 rears for autox? mike?
Old Mar 23, 2009 | 09:51 AM
Smike's Avatar
I never raced on the A046's - don't know what they would like.
Old Mar 23, 2009 | 09:54 AM
Kdash106's Avatar
how about 245/45/18s?
Old Mar 23, 2009 | 12:42 PM
sblvro's Avatar
I used 45F and 37R last weekend and was plowing throughout the cones on the stock advans. I should try 34F and 36R the next time around ?
Old Mar 23, 2009 | 12:45 PM
TxEvo8's Avatar
Each tire is going to be different in different applications and with different suspension set ups, trial and error is the best way to go..
Old Mar 23, 2009 | 12:50 PM
sblvro's Avatar
it is for an A stock evo 9 mr.
Old Mar 24, 2009 | 05:20 AM
cij911's Avatar
Are those cold temperature psi readings? What did you tires inflate to after a few session? When I was AX many many years ago (~20), the common practice was to mark the tires with chalk or tire crayon to see rollover and adjust tire pressure accordingly. Additionally folks that were more serious would use tire pyrometers to gauge proper psi and suspension setup.
Either way, my guess is 45F and 37R on A046 would be too high (I would have started more like 32 all around and then gone from there)....
Old Mar 24, 2009 | 06:03 AM
sblvro's Avatar
well that is good to know.
Medrivfast
Sep 10, 2015 06:41 PM
Kracka
17
Aug 20, 2012 09:57 AM
Evo11V
Apr 30, 2012 10:39 AM
Dbar4G63IX
Jul 24, 2010 03:56 PM
coryl
Canadian Forum
Oct 31, 2009 07:39 AM
