I did a little searching through the forums, but i still didnt get a definite answer.
Looking to do some sway bar upgrades, Whats the difference between the mm?
I see that some are anywhere from 21mm to 25mm, Should i have the front and rear sway bars match in mm.
Whats the advantage to having 25mm or having 21mm, Thanks in advance
https://www.evolutionm.net/forums/ev...-reviewed.html
I have experience with the Swift setup. 18% stiffer in the front and 20% stiffer in the rear.
