wheel spacer and studs install?
Old Mar 22, 2009 | 01:58 PM
jerms's Avatar
I bought the h&r 15mm wheel spacers with the longer studs, what does it take to change studs? Do they need to be pressed in/out or is it pretty strait forward? Any help is appreciated!
Old Mar 22, 2009 | 02:06 PM
Smike's Avatar
Moved the hub around until the back of the stud you want to remove is clear (aka not going to hit the dust shield). Take a hammer (3-5 lbs works well here). Hit it - pops out. Put in new stud and get a lug nut. Tighten lug nut until it pulls the new stud all the way through. Repeat X times.
Old Mar 22, 2009 | 02:24 PM
jerms's Avatar
word thanks man.
Old Mar 23, 2009 | 09:16 PM
EvoPooPoo's Avatar
I'd recommend removing the hub off of the car... and if you have a press, great... if not,
do what Noize said... but off of the car, so that you don't damage your wheel bearing.
after removing, put the hub back on, and put the stud through and use a lug nut to pull through.
Old Mar 24, 2009 | 09:38 AM
Protostar1's Avatar
The Mitsubishi Tech Manual does NOT recommend taking the hub off for exchanging wheel studs. Follow Smike's procedure above, and be gentle, nothing should be forced. G/L
Old Mar 24, 2009 | 10:23 AM
kidwitevo's Avatar
dont force? lol
i removed the hub, got the factory studs out with a single swing of a mini sledge. i used a press and an axle nut socket to get my arp extended studs in. no issues. if you use the lug nut method, i stuggest retorqing on a regular basis to help the new stud seat if youre a track goer.
poonpower
Oct 22, 2016 06:35 PM
mrfred
14
Jan 13, 2015 05:30 PM
_Evoke_
Dec 4, 2014 05:15 AM
TKEVO
14
Feb 26, 2011 05:06 PM
Justindc2
Jun 21, 2007 07:33 AM
