Brakes squeaking badly!
Old Mar 22, 2009 | 03:46 PM
mayday3k's Avatar
Just got the rotorpros slotted rotors with zync plating and the Hawk HPS break pads on and they squeak very loud! Is this due to the zync plating or the pads? It not all the time they are squeaking but here and there. Anyone know? Thanks
Kevin
Old Mar 22, 2009 | 03:51 PM
migs647's Avatar
Give them some time to break in. Did you grease the pistons?
Old Mar 22, 2009 | 05:25 PM
mayday3k's Avatar
yea, the squealing seems to be going down... how long will this go on for...
Old Mar 22, 2009 | 05:26 PM
markymark1082's Avatar
couple days
Old Mar 22, 2009 | 06:06 PM
getcha's Avatar
Kevin where did you end up getting your RPs from?
btw- did you finish up your tune? I saw your install thread on the other board
Old Mar 22, 2009 | 06:22 PM
LV///R's Avatar
Did you bed-in the pads/rotors after you installed them?
Old Mar 22, 2009 | 06:57 PM
Puppetmaster's Avatar
What he said ^^
Also, is the squeaking only when the brakes are cold? HPS tend to do that, in my experience, which is all of two sets, haha.
Old Mar 23, 2009 | 06:59 PM
mayday3k's Avatar
I had a local shop do the work due to my busy schedule. This is a pretty reputable shop too so I am assuming the work was done properly. And the squealing happens when it's hot and cold but mainly when hot. WTF?
Old Mar 23, 2009 | 07:02 PM
mayday3k's Avatar
Before I do anything I'm going to give it a few days. I haven't really been on the brakes much due to the squealing. Could the zinc plating have a part with this? Also I got the rotors from maperformance.com
Old Mar 23, 2009 | 07:04 PM
LV///R's Avatar
Have you bed-in the pads though? I'd try that once and see what happens. Some pads will be a bit louder than others. But start with the bed-in, and let us know what happens then after it.
Old Mar 23, 2009 | 07:20 PM
spool_sample's Avatar
^^^ What he said, plus -
Did you put shims in when you changed the pads?
HPS should hardly be loud at all.
Old Mar 23, 2009 | 07:22 PM
RoyalNATI's Avatar
Hawk pads are known for squeaking very loud. I installed them 3 months ago and still hear it.
Old Mar 23, 2009 | 08:20 PM
LaminarFlow's Avatar
I got cheap Axis pads a month ago (dd pads).. squeaking was bad. did the proper bed in process once.. little help.. regreased backs.. bed in process again.. sqeaking is reducing but still there. There are no backing plates though. I think if i did, the squeaks would go away faster. lesson learned: get backing plates if don't have any, grease well and and do bed in process.
Old Mar 23, 2009 | 08:25 PM
evoseller888's Avatar
do bed-in and give few days
Old Mar 25, 2009 | 06:57 PM
Sniper9's Avatar
I'm having the same problem. Except I did not change my rotors. Its been about 2 weeks since I've had them installed. It happens mostly after they warm up and when I apply the brakes lightly to come to a slow stop at low speed the brakes SCREAM not squeek and it does not seem to be getting any better.
