How do I reduce bounce and body roll?
I apologize for the vague nature of my post. I've had the following setups:
1) Stock + Advans,
2) Stock + Kumho ASX
3) Megan Track + Kumho ASX
4) Megan Street + Kumho ASX
5) Megan Street + Dunlop Z1 Star Spec
To me the best feeling was the stock suspension with Advans. By best I mean I liked the firm, planted feel when I took turns. Now my big complaint about Megans (regardless of rebound setting) is the fact that they feel "bouncy". I thought this was just having crap tires (Kumho) but now with the new Dunlop tires I still feel that the car has too much body roll and bounce. This feeling was on both Megan Street/Track versions. On Saturday, I am going to try a members MR Bilstein and Swift Type R springs setup. I use the car for aggressive street driving. Any thoughts on if the spring shock setup will give me the feel I am looking for? Any other suggestions are appreciated.
1) Stock + Advans,
I'd toss out the Kumho ASX options due to them being a/s. If you don't need winter traction look at the summer tire combo. Their tread design and depth won't help reduce pitch/roll, especially compared to the oe Advans.
Best way to reduce the roll is by lowering the car. May also want to install an anti roll/sway bar, that will help a lot. The right tire will do more for steering response than pitch/roll.
Thanks.
what roll center adapters http://www.rallysportdirect.com/shop...64f65813dd51db
The biggest problem is your spring rates. I have the exact same coilovers as you and no bounce. I swapped out the front springs with an 8kg springs instead of the 12kg. Also the EVO should have higher spring rate in rear due to the multi link rear suspension. In my case it's 8f/10r. I think I paid $45 for brand new front springs shipped off ebay.
http://www.meganracing.com/products/...d=350&catid=93
The site says I have 7kg Front and 8kg Rear?
Just checked and I currently have
8kg Front and 6kg Rear
The track series felt bouncy. So the middle ground is where it's at?
Its much better to account for our suspension geometry.
One thing you can do is to swap the 8k to the rear and 6k to the front. The way our rears are set up the spring rate is diminished do to how the geometry is. So the 6k rear is more like 4k taking that into account.
Good read:
https://www.evolutionm.net/forums/ev...-your-evo.html
Good read:
TouringBubble
62
Aug 7, 2012 09:57 PM
ancker
10
May 19, 2007 04:57 PM
greekven
14
Nov 4, 2006 08:48 AM
shortdahri
16
Oct 16, 2006 05:56 AM
welcome!
